Home > Technical (L322) > Need urgent help
tiddles1991
United Kingdom 2004 Range Rover Vogue Td6 Buckingham Blue
Need urgent help
Went to my Vogue earlier and the battery was bang flat, I couldn't get nothing out of it. After a lot of messing about trying to get a car close to mine to jump it, it finally struck up.
I had to reset the air suspension setting which I did, only problem I have is my passenger front window won't go up. Nither will the electric wing mirror work. The wing mirror im not immensely concerned about that can be done whenever but I need the window up!
Any thoughts on what's happened? Also my sat nav wasn't working before but now it is, I disconnected that incase the battery was favouring the sat nav instead of the window but it's made no difference.
Any thoughts?
Post #396267 15th Jul 2016 8:25pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Tiddles, purely down to the charge in the battery, yes you have started it but it needs more charge Thumbs Up
Post #396268 15th Jul 2016 8:28pm
tiddles1991
How long do we think it'll need to get going? I've had the engine on around 75 mins now and no progress. What I will say is I switched it off and then on again and the rear windows began to work. I was hopeful it would fix the passenger side too!
Post #396270 15th Jul 2016 8:33pm
Rosco
Cant help on that one, had the same problem a while back on a similar aged car, will sort itself out, a hard reset may help, do a search on that one, is a pain in the arse I know Thumbs Up get a new battersy asap Thumbs Up
Post #396271 15th Jul 2016 8:37pm
tiddles1991
I keep reading about battery problems with the l322. Will it be the battery or could it be that I may of left a interior light on by accident Embarassed
Post #396272 15th Jul 2016 8:40pm
tiddles1991
And thanks for your help Very Happy
Post #396273 15th Jul 2016 8:40pm
Rosco
Mate, I see you have just acquired it, First thing - take a deep breath, you need a battery, number 1, there could be a number of things draining it e.g. are your headlight wipers in the correct position? Dont worry re windows they need a good charge before they will work properly, put a tarp over it tonight if you need to, welcome to FF ownership, definitely worth it in the end Thumbs Up
Post #396275 15th Jul 2016 8:45pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
This is no help whatsoever, but I have mine for 4 months now and it seems like the things going wrong with it are never ending - the very first being the battery committing suicide after the fist week. At least there is no problem finding something to do at the weekends... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #396276 15th Jul 2016 8:59pm
tiddles1991
Done a hard reset and its seemed to of solved the problem, noticed my window wipers was set to the back ones being ok so maybe it was this? Will keep an eye on it for a few days! Thanks again
Post #396294 15th Jul 2016 10:14pm
RR2008HSE
Battery and alternator. They're usually step 1 & 2 when weird things happen. If alternator is good, take out the old one, let it sit overnight, then add a nice, good, fully charged battery and see how things are. It doesn't solve everything, but it's a place to start. Good luck.
Post #397211 22nd Jul 2016 10:19pm
