![]() | Home > Maintenance & Mods (L322) > Side Steps and jacking? |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 ![]() ![]() ![]() |
I had therse on my MY2010 needed a tyre changed due to puncture. The garage i took my car to used one of those "proper" trolley jacks and didnt need to remove the steps. Had no issues, 2011 5.0SC Santorini Black
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
I have changed tires on our 07 ffrr with retractanle side steps, no problem. Just lock the steps on the outer settings, use a hydraulic garage lift, will not conflict with the steps. |
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
I've used a merc sprinter bottle jack, much reported on this site, on the normal jacking points. There is a small area between the step and the wheel which allows up and down movement of the jack handle. Works ok. Small and easy to use jack with good lift. |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8091 ![]() ![]() ![]() |
You can't use the supplied scissor jack in the boot on the factory jacking points.
Slaav Member Since: 02 Mar 2014 Location: GLos Posts: 32 ![]() ![]() |
Thanks all, and thanks for that link to the old thread.
