![]() | Home > Technical (L322) > reduced performance |
kbald Member Since: 17 Aug 2015 Location: Leeds Posts: 492 ![]() ![]() ![]() |
Could be split hoses if it happens underload. I'm assuming it's a diesel?? Were there big clods of smoke coming out of the back when it happened? |
Terrier Member Since: 17 Dec 2015 Location: Yorkshire Posts: 51 ![]() |
No, nothing like that. I did notice a little water discharge underneath however I put that down to air con. |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 ![]() ![]() |
Get it plugged in to diagnostic soon as you can. Is this where I put the car details and a bit about myself ?........ |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
3.6?
Apologies chaps, she's an oil burner TDV8 |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8085 ![]() ![]() ![]() |
3.6 or 4.4 ?
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2742 ![]() ![]() |
If its a 4.4 and still has the original secondary turbo inlet isolation valve then the valve could be sticking. |
5 minute job to check them and you only need a screwdriver. Have a search on here loads about it. If they are fine atleast you can rule them out without paying someone to check these for you! |
You're in Leeds, fancy a pint? |
Is it a 3.6 or 4.4 |
It's certainly the weather for a pint or 3 that's for sure!!
4.4 TDV8 rotary knob |
You're not wrong, I've just lifted the hood and she's still red hot and I've been home since 5:30. It's very busy under there. My good lady took a look and said "everything looks ok". So that's that then! |
This thread might help - I don't know much about the 4.4's (even though I have one |
