![]() | Home > Maintenance & Mods (L322) > EGR blanking |
gregdav Member Since: 26 May 2014 Location: just north of stafford Posts: 1077 ![]() ![]() ![]() |
Find a suitable size bolt or pin, push in the end of the vacuum hose, that's it. When your blanking kit arrives, their should be a blank metal stud that protrudes from the right hand side as you look at it, remove your bolt and place the vacuum hose on there.
wayneg Member Since: 05 Jun 2013 Location: South Fremantle, Australia ( ex London ) Posts: 807 ![]() ![]() ![]() |
If you want to clean out the egr, take a look at this video, not exactly like the td6 but very close. I would not bother myself, just fit the new delete kit and plug the vacuum hose. More of a concern would be the build up of black gunk in the inlet manifold. Now that is one nasty job.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35828 ![]() ![]() |
why not wait for the egr blanking kit and save yourself a job.. ... - .- -.
frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56 ![]() ![]() |
i was bored during my lunch break. so went outside and pulled the pipes off the egr. i had a look inside and its got some build up, not much, actually more of a smear on the plunger, which is in the open position.
Hmb Member Since: 12 Jun 2016 Location: Essex Posts: 90 ![]() ![]() ![]() |
Your engine will Rev to limits you didn't know existed |
If its past the redline thats fine, its only in the area of the redline that worries me. |
