Home > Maintenance & Mods (L322) > EGR blanking
frikkadel
South Africa
EGR blanking
I have just read on Joe90's album of the EGR removal, that at the end he blocked the vacuum hose of as he wanted to disable the unit.
My question is, i want to clean out my EGR while waiting for a blanking unit, do i leave the unit in the open position and also put a nut where the vacuum hose goes in?
will the engine run normal now once that is done and will it block up again?
Post #396699 19th Jul 2016 8:45am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Find a suitable size bolt or pin, push in the end of the vacuum hose, that's it. When your blanking kit arrives, their should be a blank metal stud that protrudes from the right hand side as you look at it, remove your bolt and place the vacuum hose on there.
you won't regret doing this mod.
greg Thumbs Up
Post #396721 19th Jul 2016 11:42am
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
If you want to clean out the egr, take a look at this video, not exactly like the td6 but very close. I would not bother myself, just fit the new delete kit and plug the vacuum hose. More of a concern would be the build up of black gunk in the inlet manifold. Now that is one nasty job.
https://www.youtube.com/watch?v=Mek4GowitXk 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #396722 19th Jul 2016 12:08pm
why not wait for the egr blanking kit and save yourself a job.. ... - .- -.
Post #396725 19th Jul 2016 12:18pm
frikkadel
South Africa
i was bored during my lunch break. so went outside and pulled the pipes off the egr. i had a look inside and its got some build up, not much, actually more of a smear on the plunger, which is in the open position.
My quick question is , can i spray into the egr with some wynns carb cleaner, that stuff cleans, i ask as i am not sure what the egr is attached to, will it damage anything if i spray there.
and can i put all the pipes back and then block off the vacuum?
my gloves await me to put them on and continue.
Post #396726 19th Jul 2016 12:30pm
Hmb
England 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Your engine will Rev to limits you didn't know existed
Post #396743 19th Jul 2016 2:27pm
frikkadel
South Africa
If its past the redline thats fine, its only in the area of the redline that worries me.
Post #396744 19th Jul 2016 2:34pm
