![]() | Home > Maintenance & Mods (L322) > Red oil coming out of zf 5hp24 gearbox |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
At least is IS red, and not black!
smiler289 Member Since: 11 May 2016 Location: matlock Posts: 124 ![]() ![]() |
Couple of pictures showing red oil on tissue. Hacked at sump filler plug so someone has been at it before and the plate on side of gearbox, there is 4 on end I just didn't get the picture right. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Red fluid usually means Dexron, or one of the ‘multi-purpose’ inventory reduction fluids. Oh dear |
Eventually got it all back together. Main aim of the job was to change the transmission oil temperature harness, that was no problem,a little fiddly in parts. I didn't count on there being a different oil in the sump or somebody using sealant on both sides of a gaskets. Managed to get most of it off or smooth enough. There doesn't appear to be any leaks so far. The liquid that came out seamed to be fairly clean and not much metal fragments on the magnets.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
What milage have you got?
Owned just a couple of months. Around 86000 miles. |
most likely you have had a major service done on the trans then.
Forgot to say, my fluid is a cherry colour LT 71141 fluid.....I use Liqimoly product. If you are not experiencing any problems with the trans it is most likely the correct fluid. |
When I bought it the garage said it looked like it had a new box on it but no paperwork to back it up. Yeh am using the correct fluid. The harness I replaced looked old though. |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
This is good to know. Didn't know any were colored other than that golden color. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8817 ![]() ![]() ![]() |
If it's cherry colour then it is definitely not the correct fluid, it might be advertised as compatible or equivalent but it will not have the correct friction modifiers unless it is genuine Mobil LT71141, which is straw coloured.... |
I have been using this for the last 3 years......its cherry coloured.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
You may not have had any issues yet but if the fluid is any other colour than straw and is not the Mobil LT71141 then you are destroying your transmission from the inside. The ZF units will ONLY work (and survive) with the correct oil. Non genuine oils basically wear away the internal part costings. (As kindly shown by RRPhil) and are breaking down due to the incorrect friction material. The fluid is quite expensive but this is for a reason, if you have any other oil you should really get is flushed and changed straight away.....if it's not too late! Speak to RRPhil about this as he is the ultimate expert in this field.
The liqimoly does list LT 71141 applications with this product. |
