![]() | Home > Technical (L322) > drivers door wiring problem |
espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86 ![]() ![]() ![]() |
hmm
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
thanks for the reply all wires that were connected to switch module were not disconnected both speakers are working normally .can not for the life of me see another connection. i must be missing something there are 3 connectors with multi wires going to switch. box these wires were left in situ. speaker wires were disconnected and i must have pulled these mystery wires out but from where i just can not see i have ordered new cable for door opener and will wait till it comes before taking apart again any ideas would be great richard |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
Air bag?
i do have air bag and it is still connected. these wires come from loom in the door and look like they should go to card somewhere very similar to speaker wire connection |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
What colours are the wires? John
i think brown and blue but i would have to take card off to check i stupidly did not take pics of it when i put it back together but they are dark colours |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
The wires aren't for the puddle lights in the bottom of the door card or the door handle leds by any chance?
Don't how how far this will take you but behind the driver's door panel the wire colours are:
thanks for that will take door card off when new door able arrives everything is working including puddle light windows central locking speakers its just the air suspension no lights on hight selector switch at all |
I'm pretty sure that as you have no lights at all on the air suspension switch panel a hard fault has been logged on the ECU for whatever reason which will require to be cleared by connection to a diagnostics unit. |
ok do you think i have done something inside door to cause this? |
I'm afraid I simply don't know.
will check fuses tomm .would have done but can not see any reason they would have blown |
hi folks all is well again fuse was ok .took panel off and on with new door cable. working fine odd wires go nowhere .had to do reset at local garage air susp fine a lesson to be learned not to leave ones light on all night .going to have a cable fitted from battery to caravan socket wont get caught like that again. |
