Home > Technical (L322) > drivers door wiring problem
rik
Scotland 2003 Range Rover Vogue 4.4 V8 Bonatti Grey
hi folks on leaving my sidelights on all day and night and a call out from aa finally got some power to battery and got her open started no probs battery ok however on trying to open drivers door which would not open with key i snapped cable for outside door handle so card off door to find problem ok needs new cable when wiring speakers etc back i have 2 spare wires 2 into one blue small connector pin hole connections pretty much same as small speaker connections ok so searched everywhere for somewhere to connect to without any joy put card back on everything working ok exept air suspension has stopped working no lights can anybody shed some light as to where these wires go as they must be cause of failure suspension was working fine after battery charged any help would be much appreciated richard
Post #396756 19th Jul 2016 5:02pm
espaceboy
hmm
sure you haven't plugged the wrong cable into the door access mode connector on the driver switch pack?
I seem to recall a post that its possible to transpose the wiring to a couple of the connectors on the switchpack , one of them being the access height control connector
Post #396784 19th Jul 2016 9:34pm
rik
thanks for the reply all wires that were connected to switch module were not disconnected both speakers are working normally .can not for the life of me see another connection. i must be missing something there are 3 connectors with multi wires going to switch. box these wires were left in situ. speaker wires were disconnected and i must have pulled these mystery wires out but from where i just can not see i have ordered new cable for door opener and will wait till it comes before taking apart again any ideas would be great richard
Post #396801 20th Jul 2016 1:06am
Clivefog
Air bag?
Something you have not got but is included with the loom?
Post #396802 20th Jul 2016 7:05am
rik
i do have air bag and it is still connected. these wires come from loom in the door and look like they should go to card somewhere very similar to speaker wire connection
Post #396808 20th Jul 2016 9:11am
Weegie
What colours are the wires? John
GAP iiD BT-Sold
Post #396812 20th Jul 2016 9:45am
rik
i think brown and blue but i would have to take card off to check i stupidly did not take pics of it when i put it back together but they are dark colours
Post #396821 20th Jul 2016 10:52am
The wires aren't for the puddle lights in the bottom of the door card or the door handle leds by any chance?
With regard to the air suspension not working I would be inclined to take the door card off again and one by one un-plug all the door connectors and then re-connect and see what happens. Thumbs Up
Post #396839 20th Jul 2016 1:28pm
Weegie
Don't how how far this will take you but behind the driver's door panel the wire colours are:
Ride Height Switch - SR/N/YG
Puddle Lamp - N/RU
Mid range Speaker - SN/SB
High Range Speaker -YB/YR
Airbag -Y/N
Anti Trap Sensor -N/NR
Window Motor -BG/BS
S = Grey
N = Brown
Y = Yellow
G = Green
R = Red
B = Black
U = Blue
There is other wiring but something to be going on with. Wink John
GAP iiD BT-Sold
Post #396844 20th Jul 2016 2:12pm
rik
thanks for that will take door card off when new door able arrives everything is working including puddle light windows central locking speakers its just the air suspension no lights on hight selector switch at all
Post #396848 20th Jul 2016 2:42pm
I'm pretty sure that as you have no lights at all on the air suspension switch panel a hard fault has been logged on the ECU for whatever reason which will require to be cleared by connection to a diagnostics unit.
Post #396868 20th Jul 2016 4:54pm
rik
ok do you think i have done something inside door to cause this?
Post #396912 20th Jul 2016 9:29pm
I'm afraid I simply don't know.
As far as I'm aware the only thing in the doors that could possibly cause a problem with the air suspension are the Hall sensors in the door locks that indicate when the doors are open and closed. It's common for the air suspension to be inhibited when a door is open but usually the indicator lights stay on on the switch panel.
I assume you have checked the fuse for the air suspension? Fuse 57, 15A on the front fuseboard behind the glove box.
Post #396915 20th Jul 2016 9:56pm
rik
will check fuses tomm .would have done but can not see any reason they would have blown
Post #396932 21st Jul 2016 12:06am
rik
hi folks all is well again fuse was ok .took panel off and on with new door cable. working fine odd wires go nowhere .had to do reset at local garage air susp fine a lesson to be learned not to leave ones light on all night .going to have a cable fitted from battery to caravan socket wont get caught like that again. Thumbs Up thank you for all the replies richard
Post #397108 22nd Jul 2016 11:47am
