Home > Technical (L322) > Air on issue
Adbseries3
United Kingdom 2012 Range Rover Westminster TDV8 Stornoway Grey
Air on issue
Hi all, am after some help. Had my 2012 RR since November and never thought the air con was great. This weekend in the hot weather I realised although it makes lots of noise, no air was actually coming from the vents hence barely cooling down. Vowing to take it to the garage, the next time I started it lots of cold air! Had that two days running, thought it had somehow fixed itself, then the next day (this morning) no air from the vents just lots of noise again. Finally this evening, lots of noise but no air, then a sucking sound, then lots of cold air!! Any ideas? No doubt when I take it in it will work fine and no one will be able to find the problem! Ideas appreciated. Many thanks.
Post #396922 20th Jul 2016 10:37pm
Mine does this sometimes.
It does it when on auto, I select all 3 of the direction buttons underneath and let it run for a while then put t back on auto.👍 There is nothing that can't be fixed with a hammer😜😜
Post #396925 20th Jul 2016 10:47pm
Adbseries3
Useful thanks will give that a try. Worked again this morning!
Post #396936 21st Jul 2016 7:20am
the ac tends not to work when just on idle, increase the rpm and it works ok.. ... - .- -.
Post #396939 21st Jul 2016 7:45am
Adbseries3
Many thanks, it seems to blow hard and ice cold even from start (when it works),but when it decides it won't then nothing comes out even though it makes all the same noise and it won't seem to kick in no matter how fast I'm going until I stop and turn it all off(and even then its random). Very odd.
Post #396943 21st Jul 2016 9:09am
Clivefog
Flap getting stuck?
Post #396957 21st Jul 2016 10:12am
Adbseries3
I think that is a good possibility given the noise continues but there is no blowing from the vents- is that something that a technical incompetent can check of fix?
Post #396965 21st Jul 2016 11:45am
