Home > Other Site Sponsors > New firmware & app release, V3.0, for the IIDTool...
Page 6 of 7 <1234567>
Andy
Lead is ok. I've done some tests with Pat from Gap and it's a faulty tool. He's swapping it for me. Thumbs Up
Post #304875 13th Jan 2015 11:34pm
chex
Kenya
Your website makes a passing reference to the PC interface but no mention in the manual of how to actually use it. How do you do it?
Post #329819 28th May 2015 5:28pm
this any help?
http://www.fullfatrr.com/forum/post229025.html#229025 ... - .- -.
Post #329837 28th May 2015 7:24pm
chex
Kenya
I see a screenshot of the windows app but still no mention of where to download? I can't find it on their site either.
Post #329838 28th May 2015 7:32pm
i see what you mean chex, the GAP chaps come on the forum regularly so i'm sure you'll get an answer soon.. ... - .- -.
Post #329840 28th May 2015 7:39pm
chex
Kenya
thanks for the help stan
Post #329841 28th May 2015 7:49pm
Bungal
United Kingdom 2008 Range Rover Vogue TDV8 Buckingham Blue
Just updated mine.
Had a few problems, the lead was one.
The guys at GAP especially Patrick were fantastic with advice.
Brian
Post #344377 25th Aug 2015 7:31pm
smighall
England 2005 Range Rover Vogue SE Td6 Buckingham Blue
Does anybody know if it's possible to upgrade / exchange to a BT version of the tool? I have the normal non bluetooth one currently but ideally want to change it. Is my only option to buy a new one?
Post #344852 28th Aug 2015 11:30am
the only peeps that will answer that is the GAP chaps , email them.... ... - .- -.
Post #344860 28th Aug 2015 11:57am
smighall
Will do Thumbs Up
Post #344877 28th Aug 2015 2:08pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi guys, just wanted to say what a great tool this is.
this is, my first diagnostic tool, never had one before.
quick question, as I have already used the tool on the interface, are my car settings stored on the tool, or do you have to physically get to a certain place to back it up, sorry if I sound a bit thick, but when I do have a play, I want to be sure my original settings are stored.
tia. Greg. Thumbs Up
Post #397374 24th Jul 2016 6:02am
The first time you plugged your tool on it should have saved all your settings and asked you to name the file but you probably didn't 😉So in the menue Save/Restore settings it will be in the first file and you will have a choice to restore EAS or CCF . 2008 MY Supercharged
Post #397376 24th Jul 2016 6:25am
gregdav
Cheers axle , quite a few things I need to learn. Very Happy
greg. Thumbs Up
Post #397377 24th Jul 2016 6:50am
Greg, have a good play with it, with the engine on or your battery will go flat... it's amasing what it can do, worth going through all the live values and noting what they are, then gives you a base line if you have problems later...
Do a calibrate on the EAS "just because you can"......
Playing just get's you familiar with what it will do....
I got stuck in Manchester with a bust height sensor and it dropped to the bumpstop on one corner, whip the IID out and within 5 mins I've pumped air into that corner and deactivated the system, driven home with no issues and fixed the sensor a couple of days later.... No tool... you're on the back of a tow truck...... Thumbs Up
Also get rid of most of the annoying bongs and turn off cold bulb monitoring on most lights as when the bulbs get old they fail a cold test but still work.... Thumbs Up Pete
-Click here for Thread-
Post #397415 24th Jul 2016 11:48am
gregdav
Cheers pete, can't wait to try it out on the bt when I get the I phone.
the adjustment of the eas on access mode was 40mm, it wouldn't go any further, so according to the iid tool, it started at 40mm and I pushed it as far as it would go down to 80mm in total. This was all 4 corners together.
must admit I enjoy the car even more now Very Happy knowing I've got the iid tool as security.
Thanks for the advice , hope you and axle have speedy recoveries.
Greg Thumbs Up
Post #397503 25th Jul 2016 7:15am
