![]() | Home > Maintenance & Mods (L322) > Alarm |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885
its normally the bonnet switch which goes faulty....loads on here re that.. ... - .- -.
| rangeseb Member Since: 06 Nov 2015 Location: Baldock North Hertfordshire Posts: 185
From what i read i need to spray WD40.
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002
If it's going off for a reason, but you don't know why, can you stop it with the fob and then lock the car using key? Is the car locked then without the alarm on? Could be wrong.
From what the Wife said on the phone, she got home locked up as normal then the alarm went off and has done another 4 or 5 times.
| PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1263
Key fob battery??? |
Going to try the 2nd key when I get in.
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Do try the bonnet switch disconnect first when you get home. .
So it could be working correctly then? Ie something legit is setting it off. You can't do anything till you get home really.
It's a Range Rover!! Ours at the moment is refusing to lock or unlock with either the remote OR the key! New key on its way though. Since the key fob has been playing up it has had a tendency to sit on the drive and start flashing the hazard lights for no reason whatsoever, and occasionally setting off the car alarm! Hoping the replacement keys and subsequent recoding will sort it out though. It did still lock and unlock though even when the key fob battery was failing, then again when a new battery was fitted it kept giving a Key Battery low warning bong! Still havent found how to disable the BAE (Bank Account Emptying!) chip though...... |
| Madmax676 Member Since: 25 Jun 2016 Location: Somerset Posts: 44
Had exactly the same on mine a few weeks ago. When ever I pulled up on the drive when the engine was hot or the sun shone on it, the bonnet would expand a bit and operate the alarm switch.
Does anyone have a picture of what I should be disconnecting?
| Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591
Daft question but has it been raining in your neck of the woods? can be an issue otherwise, leave it open until you can sort it, if they are going to nick it they will anyway |
| All times are GMT |
