![]() | Home > Technical (L322) > drivers door key not opening door |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
Can you feel any resistance to the key turning or is it quite loose? Could be the extension on the lock barrel broken or just come out of the receiver. |
DO NOT TAKE THE DOOR CARD OFF, do not touch the door card, there is no need to remove it, only remove the outer handle and lock and reset the cam to the central position.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35743 ![]() ![]() |
good advice from John ^ |
rik Member Since: 21 Jan 2015 Location: argyll Posts: 265 ![]() ![]() ![]() |
thanks for that will try asap |
ok took bolt out lock wont budge there are 2 bolts holding it in. first bolt dropped into door . card. off. with the help of a magnet got it back. can not see slotted screw anywhere mabe my door is different ? removed door lock lower screw left hand thread upper screw right hand .put it all back together and wala the bloody thing is working dont know what i did sprayed everything with silicon while i was in there i will have to disconnect battery to find out if lock is working mechanically some pics of lock |
Thinking about this/ lower screw probably dont need to come out/ as there are 2 grommets i mistook this one for lock removal one hence the mystery. however i still dont know why it is working now or why it would stop working in the first place .any clues ? |
