Home > Maintenance & Mods (L322) > Roof Rack
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
Roof Rack
I am considering buying one.
Has anyone got experience of any brands?
Any pictures.
There are a couple on fleebay.
Quite like to try one. 15MY SDV8 Vogue SE
Post #39875 28th Nov 2010 4:53pm
Unless you're 9 feet tall you will need a step ladder to get up to it
Post #39877 28th Nov 2010 4:55pm
Jem0911
Sad as it may seem it will only get very minor use.
For skiing trips.
Mainly for 'the look'
Not sure yet. 15MY SDV8 Vogue SE
Post #39878 28th Nov 2010 4:58pm
dan_uk_1984
Do you need a full on roof rack or will roof bars do?
LR do bars or they do roof rails with cross bars.
Post #39879 28th Nov 2010 5:02pm
Jem0911
I think I want the full Roof rack look.
What is the addition on your roof Dan?
Have seen it on a couple a FF's
Looks like a take on Roof rails but solid? 15MY SDV8 Vogue SE
Post #39881 28th Nov 2010 5:16pm
Roof rails cause extra slipstream drag and higher fuel consumption plus a lot of wind noise
Post #39884 28th Nov 2010 5:24pm
dan_uk_1984
I have roof rails, they are fixed then you just clip the bars into them when needed. The problem with a full rack is the noise and mpg loss.
Post #39885 28th Nov 2010 5:25pm
Jem0911
What are we guessing on MPG loss?
I seem ro remember Clarkson talking about 5-10% 15MY SDV8 Vogue SE
Post #39886 28th Nov 2010 5:35pm
dan_uk_1984
Rails are fitted lengthways so have no effect on aerodynamics as the leading edge is so small it keeps Frontal Pressure to a minimum also as they are one solid piece you get no Flow Detachment,
The problem comes when you fit crossbars as these cause significant turbulence, this is what causes the noise. As a result of the turbulence and frontal pressure this increases your Drag Coefficient, this is what reduces your MPG.
Post #39889 28th Nov 2010 5:59pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
thule roof bars and feet
as an occasional user of roofrack i went for the thule option. on and off within minutes, also have a choice on distance between.
Post #39894 28th Nov 2010 6:28pm
Jem0911
Re: thule roof bars and feet
David have you any pictures? 15MY SDV8 Vogue SE
Post #39907 28th Nov 2010 7:29pm
DavidP
Jem, yes indeed somewhere on this forum - a picture taken last winter in the alps.
I believe it's under my gallery. Do you want close up of how they fit?.
Post #39917 28th Nov 2010 9:03pm
Jem0911
Looks good David.
Still think I want the full Rack look.
Will take the plunge. What's the worst that can happen.
Apart from a kicking from Mrs Jem. 15MY SDV8 Vogue SE
Post #39919 28th Nov 2010 9:13pm
DavidP
For the amount of use it i'm happy. Fortunate thing was i already had the attachments, ski rack load stops etc etc.
Did look into the full rack system but decided against it when i found i had to 'cut' the covers off. The sports bars were unavailable over here at the time, well more out of stock.
Good luck which ever way you go.
Post #39920 28th Nov 2010 9:20pm
nbunney
United Kingdom 2018 Range Rover Autobiography SDV8 Corris Grey
Thule for me as well Thumbs Up
LR bars looked cheap and so Censored expensive
And the rails did not look right eihther.
Post #39922 28th Nov 2010 9:29pm
