![]() | Home > Maintenance & Mods (L322) > Roof Rack |
Unless you're 9 feet tall you will need a step ladder to get up to it |
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
Sad as it may seem it will only get very minor use.
Do you need a full on roof rack or will roof bars do?
I think I want the full Roof rack look.
Roof rails cause extra slipstream drag and higher fuel consumption plus a lot of wind noise |
I have roof rails, they are fixed then you just clip the bars into them when needed. The problem with a full rack is the noise and mpg loss. ![]() |
What are we guessing on MPG loss?
Rails are fitted lengthways so have no effect on aerodynamics as the leading edge is so small it keeps Frontal Pressure to a minimum also as they are one solid piece you get no Flow Detachment, The problem comes when you fit crossbars as these cause significant turbulence, this is what causes the noise. As a result of the turbulence and frontal pressure this increases your Drag Coefficient, this is what reduces your MPG. ![]() |
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
as an occasional user of roofrack i went for the thule option. on and off within minutes, also have a choice on distance between. |
David have you any pictures? 15MY SDV8 Vogue SE |
Jem, yes indeed somewhere on this forum - a picture taken last winter in the alps.
Looks good David. Still think I want the full Rack look. Will take the plunge. What's the worst that can happen. Apart from a kicking from Mrs Jem. 15MY SDV8 Vogue SE |
For the amount of use it i'm happy. Fortunate thing was i already had the attachments, ski rack load stops etc etc.
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2068 ![]() ![]() ![]() |
Thule for me as well |
