![]() | Home > Maintenance & Mods (L322) > Front suspension clunk |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I have an occasional clunk from the front end when going slow bumps like speed bumps. Cant find anything when on the lift. got a bar under all the bushings and joints and can't see any play. If I go over a sharp dip pot hole the tire seems to meet the bottom of the hole with force and a bang. I don't know if this is also related but at some highway speeds I get a wiggle in the steering wheel.
Testing was done on a lift. |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
OK.
So then in theory if I get it back on the lift and can put enough leverage and lift on the tire to get motion and range into the suspension parts I should see where the play is hiding? I know I have read that bushing and ball joints are common to replace as little as 50k miles.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Clunking and wobbling = front ball joints
Thanks. I will focus my attention on the ball joints first and bushings second. I would feel better seeing some play, no matter how small, before replacing the wrong or good part. |
In theory yes, but if you're looking to find a loose clunk that's easily dentified you may not find it. It could show as very small play. V8 or else ... |
I will take very small play as a sign. We could not find any play. One bushing looked not as perfect as the other side but not play. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
I know this sounds daft but the rear hub bushes wear and clonk and it sounds just like it's coming from the front, top bushes are easy to pry bar to check for wear, bottoms a bit harder.... |
I was able to put a 3 ft long bar under the right side sway bar and lift. Bushing looked good but endlink had a similar but smaller clunk and I could feel a bit if slack. So I'm guessing the endlinks are an issue. But I also noticed more inner tire wear on that tire only. Can an endlink alone produce the clunk, slight highway shimmy and tire wear on these beasts?
Bump. I though edit would do it. |
Alignment not the issue so I assume need lower ball joints/control arms along with my endlinks. They couldn't see any movement but I question how hard they tried. Is it best practice to replace the upper ball joints at this time too since you need to remove the lower to get at them anyway? |
Unsure what you mean by upper ball joint, you have a compression link at the back and a transverse link at the front, both have bushes one end and ball joints at the other...
Yeah the terminology on these parts drives me nuts. Different suppliers call the parts by different names. So I will say the bottom of the spindle has 2 ball joints. One integral to the arm often called the control arm. Sometimes this is referred to as the lower or even front ball joint. The other ball joint is just behind and sits slightly higher and bolts to the spindle. This tie rod connects to this ball joint. What I call a tie rod RAVE calls a track rod.
