Home > Technical (L322) > Rear loadspace aux socket not permanently live ?
matthews
United Kingdom 2011 Range Rover Vogue TDV8 Buckingham Blue
As title , book says it should be but it isn't 2011 4.4tdv8 , any ideas ?
Post #400869 17th Aug 2016 5:11pm
mjdronfield
Been there, done that....got well confused....
Spent nearly £200 on a cool box.
It's only live when the engine is running and until the dash goes to sleep after, or you lock it.
Manual is wrong....
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #400894 17th Aug 2016 8:37pm
mzplcg
Yep, the manual is wrong. However, you have a massive 100 amp feed in that cubby which can be used to power the socket, via an appropriate fuse of course.
Post #400895 17th Aug 2016 8:40pm
mjdronfield
And welcome to the forum....
It changed on the 2010 model year I believe. Manual must have not been updated.
You can change it with a bit of a rewire, but as the car seems to struggle to keep power to the clock without causing a flat battery, I've left mine..... I use the cool box with a couple of ice blocks in it and it's fine.... Not that that's any use to you unless you are powering a cool box......
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #400896 17th Aug 2016 8:42pm
matthews
Cheers for that , was only intending using it for phone and ecig charging so may look at a minor rewire .
Post #400915 17th Aug 2016 9:50pm
mjdronfield
Not sure if the USB is powered or if that iPod thing could be used..... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #400918 17th Aug 2016 10:10pm
matthews
USB is powered as are all the other multitude of aux sockets but all turn off after a few mins , If I'm away for weekend on pushbike I tend to want to charge phone up on a night (use viewranger on it for mapping ) and a 4.4 TDV8 battery charger is a bit excessive !, I might just hard wire (via a fuse ) another aux socket in somewhere that's easier to access as the boot socket is covered by over the top boot liner (we have 2 collies ).
Post #401218 19th Aug 2016 8:55pm
