![]() | Home > Technical (L322) > Rear loadspace aux socket not permanently live ? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7966 ![]() ![]() ![]() |
Been there, done that....got well confused....
Yep, the manual is wrong. However, you have a massive 100 amp feed in that cubby which can be used to power the socket, via an appropriate fuse of course. |
And welcome to the forum....
matthews Member Since: 09 Aug 2016 Location: Leeds Posts: 109 ![]() ![]() ![]() |
Cheers for that , was only intending using it for phone and ecig charging so may look at a minor rewire . |
Not sure if the USB is powered or if that iPod thing could be used..... 2011 Range Rover Vogue SE 4.4 TDV8
USB is powered as are all the other multitude of aux sockets but all turn off after a few mins , If I'm away for weekend on pushbike I tend to want to charge phone up on a night (use viewranger on it for mapping ) and a 4.4 TDV8 battery charger is a bit excessive !, I might just hard wire (via a fuse ) another aux socket in somewhere that's easier to access as the boot socket is covered by over the top boot liner (we have 2 collies ). |
