Home > General > Engine failsafe and air susp inactive/HDC
Page 3 of 4 <1234>
thats bad news nick...
alternator should chuck out 14/14.5 volts on idle.. ... - .- -.
Post #37262 20th Nov 2010 9:53pm
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Think kwik fit test alternator for free and round corner from work so worth a pop. Still think if alternator would have starting issues by now??
Post #37280 20th Nov 2010 10:21pm
Nickj
Had wheels balanced at kwikfit today and thought may aswell have free alternator test and they said all is well with alternator.
Worrying thing is and not sure if happened after KF or over night spell of freezing temps, but now dash lights on perm ( used to be able to turn ign off and system would work) and i have no red led on air susp knob/ height indicator at all! Think systems locked at motorway mode judging from height but no indicator.
Could them jacking it up of done something ??
Post #39814 28th Nov 2010 12:49am
Nickj
Anyone experienced no light on EAS switch?
Post #40090 29th Nov 2010 8:04pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine to is showing up this fault, someone, somewhere must know the answer!
(Just ordered EAS kicker tool (More money) Hopefully that'll work.
But interestingly enough, mine only started with this cold spell.
Post #40091 29th Nov 2010 8:08pm
Nickj
Have you lost the light (red dot and height indicator) on the switch?
Not seen much written about this. All seems to be about the dash lights ( mine on perm now)
Do be fair, its less annoying than chimes and the irractitness of before!!
Post #40113 29th Nov 2010 9:25pm
Richcl
All I have is dashboard lights + irritating bong, and scrolling message HDC inactive and Air Susp.
Post #40124 29th Nov 2010 10:11pm
Nickj
Thats how mine started. Have you tried steering reset (google if not). Can be nothing but seems could be a thousand things!!
Post #40129 29th Nov 2010 10:45pm
Richcl
Yes, replaced the battery today, and first thing I did (on start up) was steer full, left, right lock...
Still no joy
Post #40130 29th Nov 2010 10:59pm
bogie
just came across this again, I had the same errors, got a local indy to run diagnostics and it turned out to be a wheel speed sensor wire causing the issues...£17 later and 1/2 hour labour, it was sorted
so get it somewhere that can read the codes to start with ..... cheers
bogie
Post #47743 26th Jan 2011 11:30pm
Nickj
Cheers. Has 2 new front tyres fitted and seems to off been ok for a week or so!! The tyre had some large chunks out of it and was causing vibrations so wonder whether this effected a wheel sensor?
Touch wood, all's well for now but if it returns i will get it read.
Did they say why you got the 'engine failsafe message' as when researching not many air susp faults seemed to get this message.
Post #47829 27th Jan 2011 5:15pm
bogie
the wheel speed sensor affects the HDC (hill descent control) which is linked to air suspension, and ABS...and DSC ...and many more
so its a case of one dodgy sensor setting of a chain reaction of faults on the dash, but actually stored in the ECU was just one error which was the speed sensor wire cheers
bogie
Post #47887 27th Jan 2011 9:53pm
Nickj
I still don't get why it throws up 'engine failsafe mode' as to me this must be related to the actual engine and not the suspension?
Post #47889 27th Jan 2011 10:19pm
bogie
maybe yours is something different - I only had the trans prog error engine failsafe mode occasionally, not every time ...but the HDC is linked to the transmission, and on some transmission errors, it triggers failsafe mode
it can just be one thing leading to another, especially with a bit of dampy thrown in
they only way to tell is to read the diagnostics ...maybe reset all errors, go away, and then when the one big error comes back, get it read immediately and it should show what sensor etc is causing it cheers
bogie
Post #47893 27th Jan 2011 10:35pm
Nickj
Guess so. Had it read and nothing apparent at time. Hopefully won't have to worry about it again but something in me says it may be gone for now but that ping and dash lights will show themselves agian soon!!
Post #47898 27th Jan 2011 10:53pm
Page 3 of 4 <1234>
