![]() | Home > General > Engine failsafe and air susp inactive/HDC |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35671 ![]() ![]() |
thats bad news nick...
Nickj Member Since: 13 Aug 2010 Location: Ipswich Posts: 262 ![]() ![]() |
Had wheels balanced at kwikfit today and thought may aswell have free alternator test and they said all is well with alternator.
Anyone experienced no light on EAS switch? |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Mine to is showing up this fault, someone, somewhere must know the answer!
Have you lost the light (red dot and height indicator) on the switch?
All I have is dashboard lights + irritating bong, and scrolling message HDC inactive and Air Susp. |
Thats how mine started. Have you tried steering reset (google if not). Can be nothing but seems could be a thousand things!! |
Yes, replaced the battery today, and first thing I did (on start up) was steer full, left, right lock...
bogie Member Since: 06 Nov 2010 Location: Notts/Sth Yorks/Lincs border Posts: 208 ![]() ![]() ![]() |
just came across this again, I had the same errors, got a local indy to run diagnostics and it turned out to be a wheel speed sensor wire causing the issues...£17 later and 1/2 hour labour, it was sorted
Cheers. Has 2 new front tyres fitted and seems to off been ok for a week or so!! The tyre had some large chunks out of it and was causing vibrations so wonder whether this effected a wheel sensor?
the wheel speed sensor affects the HDC (hill descent control) which is linked to air suspension, and ABS...and DSC ...and many more
I still don't get why it throws up 'engine failsafe mode' as to me this must be related to the actual engine and not the suspension? |
maybe yours is something different - I only had the trans prog error engine failsafe mode occasionally, not every time ...but the HDC is linked to the transmission, and on some transmission errors, it triggers failsafe mode
Guess so. Had it read and nothing apparent at time. Hopefully won't have to worry about it again but something in me says it may be gone for now but that ping and dash lights will show themselves agian soon!! |
