![]() | Home > Maintenance & Mods (L322) > TD6 transmission fill hole confusion |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3272 ![]() ![]() ![]() |
In your first photo it is the one to the right (rear) of where you have the socket. It should be a 14mm allen key (hex key). Not much clearance between it and the subframe.
joeypineapplez Member Since: 27 May 2015 Location: Waterford Posts: 68 ![]() ![]() ![]() |
Thanks Weegie but the hex hole to the right of my socket is just a round void. Its part of the casing. Nothing to be moved there. I know its hard to judge in the photos and I did doyble check when I saw your post.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Yes, the workshop manual suggests it should be where the ‘round void’ is on your transmission casing but it looks like yours is an earlier design or something and they subsequently relocated it.
Thanks Phil. Im currently struggling to get it undone. I think they relocated it because there is no room to get good purchase on it. Spanners are slipping off it because they are at an awkward angle and there isnt room for a socket as the driveshaft is in the way. Im going to have to get creative here. Nut is close to rounding off. |
Hope you finally managed to get the plug out.
Ahh, that might explain it!
Thanks for that Phil. I knew myself there was something odd about it. Nice to know where I stand now and what all those letters mean.
Over the years the fluid requirement for the 5L40-E changed from Dexron III to Texaco Texamatic 7045E to Texaco ETL 8072B and finally to Dexron VI - the Dexron III specification having been retired in 2006. Unfortunately we don’t have the facts as to what the differences are between them (some argued that the fluid formulation was being changed as part of a continuous development to try to reduce the valve block wear problems). But to answer your question, as far as I know, Land Rover are still recommending the use of 7045E in the TD6 transmission.
