Home > Technical (L322) > The Range Rover hasn't even moved.......
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi All,
Well radiator changed, new thermostat, new water pump, all flushed out and refilled. Then came the dreaded bleeding procedure, well it wasn't bad just prolonged and took about 4 days of burping and adding coolant to get it right.
Anyway I said the Range Rover hasn't moved because it isn't taxed etc etc but I'm getting a strange problem. When I let it tick over on idle for about 20 minutes or so to warm it up and circulate the coolant to bleed it, I get air susp inactive, hdc inactive and trans fail safe, let it cool down for a few hours and the faults are gone. Now I understand driving it and getting the trans problem but it sitting on tick over is irking me because I'm not using the gearbox.
Do you think that it's throwing a fit and overheating because the bleeding hasn't been completed and I've got air in the system? You might be forgiven in thinking that I've actually driven this thing but I haven't, if you've read my other posts you'll see what I got out of the radiator and that's why I bought it cheap as a possible head gasket fault but it was the rad that was blocked and the goo that I got out of it is weird stuff....see the attached.
Anyway The car heats up fine now and the rad is evenly warm whereas before only the top right hand side as you look at it was getting hot. The bottom of the rad is cold as is the pipe running to the bottom of the rad from the thermostat bolted to the trans oil cooler and I was wondering if the thermostat is faulty or blocked, as it was the only thing I didn't swap out. And would that cause the trans fail fault?or could it be the oil cooler itself as having not driven the car the fault may well have been present and I didn't see it.
Anyway as always any help, ideas or hard drinking tips would be gratefully appreciated.
Regards to all.. ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #402233 27th Aug 2016 4:00pm
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
If you disconnected the battery you will get all manners of bongs/alerts until you move steering wheel side to side Thumbs Up
Post #402234 27th Aug 2016 4:08pm
UK Marine
Hi,
Yes I've disconnected but I've done the steering wheel moving, I have an IIDtool as well but that does no good with these faults, only good old waiting for it to cool down fixes it - kinda.
Regards to all ______________________________
Simon
Post #402236 27th Aug 2016 4:14pm
Rosco
Simon, thats about the depth of my help, hopefully someone with more skill will be along soon Thumbs Up
Post #402238 27th Aug 2016 4:25pm
Mikey
What fault codes are you getting with the IID?
Post #402241 27th Aug 2016 4:53pm
And check the gearbox oil temperature with your IID Tool Thumbs Up .
Post #402247 27th Aug 2016 5:41pm
UK Marine
Hi,
I'll have to check again tomorrow what codes it's throwing back as I'm about to go out and drown my sorrows Thumbs Up
I'll get the temps for the gearbox at the same time.
Many thanks
Simon
Post #402250 27th Aug 2016 7:01pm
holidaychicken
Have you jacked it up recently with the wheels hanging down or touched the height or ABS sensors as these can cause all sorts of problems as can a dodgy battery.
Also the wiring to the thermostat is prone to go bad with corrosion and can burn out causing a lot of electrical problems
Post #402273 28th Aug 2016 12:49am
UK Marine
Hi Chicken,
No haven't jacked it up or touched the abs sensors, I also checked the wiring to the main thermostat when I changed it and all seemed OK.
It's the other thermostat that I think may be dodgy.
Regards to all. ______________________________
Simon
Post #402281 28th Aug 2016 8:11am
holidaychicken
Re: The Range Rover hasn't even moved.......
Regards to all..
Naked bar or spoofing for drinking a pint of pi55? Wink
Post #402283 28th Aug 2016 8:29am
ebajema
To me it sounds like your problem may be low voltage at tick-over from the alternator. If the alternator is not charging very well at the low RPM, than the voltage will drop and that generates all kinds of interesting faults in a FFRR !!!
Check the voltage on tick-ver and hopefully that is the answer. May need a new alternator though and that is not great but at least you know what the issue is.
Also check for wiring connector corrosion, battery clamp corrosion etc. Just to rule out other low voltage generating issues. MY 2010 5.0 SC Galway green and sand interior!!
Post #402320 28th Aug 2016 3:07pm
UK Marine
Hi,
Sorry it's taken so long to add to this post but I've been a bit busy on other projects,
Anyway I tested the voltage this morning, battery 12.6v no engine running, 13.8 - 13.9v tick over and 12.65v with lights, heater, heated screen etc.
So it looks like the voltage regulator is u/s because as soon as I put it under load it drops quite significantly.
Looks like I'll be refurbishing my alternator.
What's your views guys?
Regards ______________________________
Simon
Post #406042 23rd Sep 2016 2:22pm
mzplcg
I would be checking all the earths, battery terminals, etc. A bad earth will also cause voltage drop, especially as load increases.
Post #406043 23rd Sep 2016 2:34pm
holidaychicken
It would certainly be worth checking all your wiring and have a google about in depth testing the alternator but i think it would point towards the alternator as should be charging at over 14 volts.
i have had a read about getting the alternators refurbished or doing it yourself so the information is out there
Post #406068 23rd Sep 2016 5:20pm
UK Marine
Cheers my friends, I'll have a go with all of your suggestions especially the earthing points.
Simon
Post #406118 23rd Sep 2016 10:49pm
