![]() | Home > Technical (L322) > The Range Rover hasn't even moved....... |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
Hi All,
Hi,
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
Simon, thats about the depth of my help, hopefully someone with more skill will be along soon |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1865 ![]() ![]() |
What fault codes are you getting with the IID? |
And check the gearbox oil temperature with your IID Tool |
Hi,
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Have you jacked it up recently with the wheels hanging down or touched the height or ABS sensors as these can cause all sorts of problems as can a dodgy battery.
Hi Chicken,
Naked bar or spoofing for drinking a pint of pi55? ![]() |
To me it sounds like your problem may be low voltage at tick-over from the alternator. If the alternator is not charging very well at the low RPM, than the voltage will drop and that generates all kinds of interesting faults in a FFRR !!!
Hi,
I would be checking all the earths, battery terminals, etc. A bad earth will also cause voltage drop, especially as load increases. |
It would certainly be worth checking all your wiring and have a google about in depth testing the alternator but i think it would point towards the alternator as should be charging at over 14 volts.
Cheers my friends, I'll have a go with all of your suggestions especially the earthing points.
