![]() | Home > In Car Electronics (L405) > TV Problem |
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1508 ![]() ![]() ![]() |
try changing settings and change back, sounds like its got stuck. |
Macpaul Member Since: 26 Jul 2015 Location: SW Surrey Posts: 100 ![]() ![]() |
I've been out to it and all it's got under TV Settings is Traffic, News and TV Country.
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Would removing the relevant fuse not help? (Although you may lose other accumulated info - avg mileage / speed etc) . Thinking if the software had locked up, then removing power may reset it to factory default after a short period or the like? Steve
That's quite a canny answer that hadn't occurred to me but in the end I took it back to the dealer who beat it with a blunt stick for a couple of days and put it right.
Is it like the old system where it only keeps the channel you last watched and you need to auto-tune every time you park up to watch TV? 2008 MY Supercharged
No, you can store up to 12 TV channels, just like in the radio but if you're not within range when you select them, you won't get them, obviously.
