![]() | Home > Technical (L322) > Lower glove box issue |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6824 ![]() ![]() ![]() |
Has no-one ever had this problem then? Got - 2017 SDV8 Autobiography in Loire Blue
Alan, not had this myself but I did go through te indignity of being unable to open the lower glovebox. (flat battery) If you want a laugh actually, read here http://www.fullfatrr.com/forum/topic2588.html?highlight=let
Cheers for that, I did wonder about the opening mechanism taking too much current but it "blows" as soon as I turn on the ignition rather than when I hit the button to open the box.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2286 ![]() ![]() ![]() |
Alan did you ever get a resolution to this as I am in a similar position with the same symptoms |
Sadly not, no. I have another new switch but I haven’t had the time, or the decent weather to check for a pinched wire somewhere behind the dash. Got - 2017 SDV8 Autobiography in Loire Blue
Well I have the same after having the box out to install steps so my glove box is in my office will have a look next weekend if I find anything will let you know |
Mine started when I ran a power cable to feed an external sat nav, so I’m convinced it’s a pinched cable somewhere tha I just need to find. Got - 2017 SDV8 Autobiography in Loire Blue
jncunliffe Member Since: 01 Mar 2013 Location: Dorset Posts: 8 ![]() ![]() |
Hi, I don’t suppose you ever solved this one did you?
Put a new switch in all fine |
Thanks. I’ll give that a go. Still can’t see why it’s needed but that’s Land Rovers for you..... |
I tried several new switches and each time it burns out. |
That’s not very reassuring. Anyone any ideas...? |
Hi,
Good find! Only JLR could give such a simple device a complicated name |
