![]() | Home > Technical (L322) > Lower thermostat modification V8 4.4 M62 2002-2005 |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
A great write-up Pete.
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Brilliant Pete, that's taken a lot of the mystery and apprehension away for me.
| verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952
Pete, you simply ROCK!
| Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267
Yes great info Pete,something I will certainly concider |
Hi Pete,
| p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1587
I reused the O-ring. Regarding not using sealant on the paper gaskets, my kit came pre-assembled. Had it not, I would have used sealant. Mine is weeping very slightly at the paper gaskets. Ron B. VK2OTC
Ok, thank you.
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826
Yep, use the "O" ring again without a gasket at that end, gasket goes between the three leaves and another against the water pump.
Good man, thank you very much ______________________________
| Xray charlie Member Since: 22 Jul 2016 Location: Derby Posts: 48
Pete,
Yes. it's a weird sensation.... Pete
| desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60
Good find Pete, Got a question though, even at the coldest we don't even come close to single digit temps in centigrade and in summer high 40s or even 50C, it was 45C-ish todayi, and since you mentioned you ran without a T,stat for months, I'm thinking of getting rid of it althoghter, one less thing to worry about.
There is the argument that it may effect the flow in the system which "could" cause problems, in reality I don't think it would make much difference, if I were you I'd give it a go, it doesn't take long at all for it to get upto temp in the summer here so I can't see it's an issue there....
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672
Hey Pete why this mod vs just using a 740D thermostat? |
| All times are GMT |
