![]() | Home > Maintenance & Mods (L322) > Mercedes Sprinter Bottle Jack |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
Afraid I dint know if you can get them pre-drrilled. Declan
Sharky1168 Member Since: 21 Jul 2015 Location: Rochdale Posts: 23 ![]() ![]() ![]() |
Many thanks for the hints/talk through....purchased & modified mine on Friday and it works a dream (sadly the guy on fleabay no longer has the tools to go with the jack) The 16mm HSS drill bit was expensive at £12, but did the job perfectly. Current RR L322 TDV8 VOGUE
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
I would say no as the arms aren't designed to take high loading in that direction.
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Ta.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1480 ![]() ![]() |
IIRC, In the manual, its explicitly stated thats not to be used as a jacking point.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1466 ![]() ![]() |
As berkshirelad says, they are not designed to take loads in that direction. The weight of the FF is taken on the air suspension system and those arms are only designed for steering geometry etc. Although people do jack vehicles up in some seemingly convenient places this would be a point load of at least a tonne on that arm. Can't see how its more convenient than the proper jacking points. If the jack is too short, support it on a sleeper or something solid. If you absolutely must do it there, for your own safety please use an axle stand before you remove the wheel. 2021 D350 Fifty Edition - Carpathian Grey 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Thanks ______________________________
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Jacking on the arms is a hazardous operation and result in the jack slipping |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
Is there a source of pre-modified jacks? |
Like this?
I meant with the top already modified for Rangie use (so the "ears" removed).
On some jacks all you have to do is drift a pin out and change the top for a Mini one from ebay , or as in my case it was a different type and I had to cut the lugs off which took four disks on the Grindet and about half an hour to get the shape just right . 2008 MY Supercharged
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3267 ![]() ![]() ![]() |
You still need to drill the mini one to fit on top. 16mm. John
