Home > Maintenance & Mods (L322) > Mercedes Sprinter Bottle Jack
Declan303
Ireland 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Afraid I dint know if you can get them pre-drrilled. Declan
2003 FFRR Vogue 4.4 V8
97 Defender 90 300 TDi
Post #404568 13th Sep 2016 1:21am
Sharky1168
Thanks gents
Many thanks for the hints/talk through....purchased & modified mine on Friday and it works a dream (sadly the guy on fleabay no longer has the tools to go with the jack) The 16mm HSS drill bit was expensive at £12, but did the job perfectly. Current RR L322 TDV8 VOGUE
Past: RR L322 TD6 HSE, Discovery 2. Land Cruiser V8, Saab 9-7x, Nissan Maxima, Ford Granada I, II, III
Post #405120 17th Sep 2016 11:30am
rar110
I have a Sprinter jack on the way. I have another smaller D1 jack and was wondering if the front suspension arms are an acceptable jacking point?
 ______________________________
Post #405282 18th Sep 2016 8:33pm
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I would say no as the arms aren't designed to take high loading in that direction.
They are designed for a longitudinal load with bushes allowing vertical adjustment
Post #405342 19th Sep 2016 10:57am
rar110
Ta.
Has anyone used a bottle jack on a L322 this way? ______________________________
Post #405685 21st Sep 2016 8:42am
fisha
IIRC, In the manual, its explicitly stated thats not to be used as a jacking point.
but
i've used it numerous times as its quick and easy when you just need the wheel off the ground for a short time.
Really you want to be jacking either the points on the sills, or the supporting subframe that the arm bolts to. V8 or else ...
Post #405699 21st Sep 2016 10:32am
Rob99
As berkshirelad says, they are not designed to take loads in that direction. The weight of the FF is taken on the air suspension system and those arms are only designed for steering geometry etc.
Although people do jack vehicles up in some seemingly convenient places this would be a point load of at least a tonne on that arm. Can't see how its more convenient than the proper jacking points. If the jack is too short, support it on a sleeper or something solid.
If you absolutely must do it there, for your own safety please use an axle stand before you remove the wheel. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #405704 21st Sep 2016 10:49am
rar110
Thanks ______________________________
Post #405722 21st Sep 2016 12:40pm
miggit
Jacking on the arms is a hazardous operation and result in the jack slipping Shocked
Sprinter jack... there are several types that I have seen over the years... some are a short lift designed to go under the axle..... some even have a scissor jack Shocked Shocked But they do look totally different to the original highly desired 2 stage blue jacks that stick 2 fingers up at the rest Thumbs Up
There might be a more readily available source from the Dodge Ram Sprinter from the US of A.... the Americans have invented a Dodge that looks exactly like a Mercedes except for the grill badge Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #406032 23rd Sep 2016 12:56pm
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Is there a source of pre-modified jacks?
Post #406045 23rd Sep 2016 2:53pm
miggit
Like this?
http://www.ebay.co.uk/itm/BRAND-NEW-Merced...SwFdtXzosE
Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #406047 23rd Sep 2016 3:17pm
Emperor Mong
I meant with the top already modified for Rangie use (so the "ears" removed).
Not sure I could do it myself. Well, I could if I had the time. And the tools. And the skills. Other than lacking those, I'm very handy.
Post #406056 23rd Sep 2016 4:06pm
miggit
Rolling Eyes Ahh, so your not after a pre-modified jack, you want a completely modified without the messy bit Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #406122 24th Sep 2016 1:29am
On some jacks all you have to do is drift a pin out and change the top for a Mini one from ebay , or as in my case it was a different type and I had to cut the lugs off which took four disks on the Grindet and about half an hour to get the shape just right . 2008 MY Supercharged
Post #406125 24th Sep 2016 4:37am
Weegie
You still need to drill the mini one to fit on top. 16mm. John
GAP iiD BT-Sold
Post #406128 24th Sep 2016 7:12am
