![]() | Home > Technical (L322) > Rough idle on 2002 Vogue 4.4 V8 with lpg conversion |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8741 ![]() ![]() ![]() |
Do some googling on those fault codes but I'm pretty sure that is your camshaft position sensor starting to fail... timing would give the fault you are getting... |
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
I found the SHFT in a different menu and got readings from -14 + 18
Sorry Pete I was out and about gathering readings and didn't read that properly! So Meeknet gives a fairly thorough write up on replacing these? http://www.meeknet.co.uk/e31/BMW_E31_840ci...cement.htm |
It's unusual for them both to fault... maybe worth a bit of reading to see if it's an indication of something else failing.... maybe it is a vanos issue and they are out of alignment or something and the ECU thinks the sensors are faulty... the diagnostics works in a very basic way, it can't tell if the sensor has failed, it just knows it's getting the wrong reading from them, and that could be because of a number of issues... Try the BMW forums for answers... |
Thank you buddy
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Deleted post |
