Home > Technical (L322) > Rough idle on 2002 Vogue 4.4 V8 with lpg conversion
Do some googling on those fault codes but I'm pretty sure that is your camshaft position sensor starting to fail... timing would give the fault you are getting... Thumbs Up Thumbs Up Pete
Post #404654 13th Sep 2016 6:06pm
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I found the SHFT in a different menu and got readings from -14 + 18
Hmm so Camshaft means Vanos issue - this is a marathon fix right!?
Post #404666 13th Sep 2016 7:02pm
ohuntsman
Sorry Pete I was out and about gathering readings and didn't read that properly!
So Meeknet gives a fairly thorough write up on replacing these?
http://www.meeknet.co.uk/e31/BMW_E31_840ci...cement.htm
Post #404668 13th Sep 2016 7:18pm
It's unusual for them both to fault... maybe worth a bit of reading to see if it's an indication of something else failing.... maybe it is a vanos issue and they are out of alignment or something and the ECU thinks the sensors are faulty... the diagnostics works in a very basic way, it can't tell if the sensor has failed, it just knows it's getting the wrong reading from them, and that could be because of a number of issues... Try the BMW forums for answers... Thumbs Up Pete
Post #404676 13th Sep 2016 8:08pm
ohuntsman
Thank you buddy
Bow down
Post #404682 13th Sep 2016 8:36pm
Dolphinboy
Deleted post Whistle
Post #404683 13th Sep 2016 8:41pm
Danwilderspin
I am having very similar issues to the op - did the sensor fix the problem?
Do they always put a code in when failing as I don’t have one? Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #474971 6th Apr 2018 8:25am
