![]() | Home > Technical (L322) > Windscreen wipers go thud thud thud thud thud thud thud thud |
cowman Member Since: 24 Jul 2013 Location: United Kingdom Posts: 186 ![]() ![]() ![]() |
i use bosch 808 they are the best i find ,i used some cheaper ones once and had the same problem as you but not with the bosch ones |
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2589 ![]() ![]() ![]() |
There is a few threads on this subject, I changed to Bosch Aero blades and cured all thuds |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3264 ![]() ![]() ![]() |
Wiper blades worn out. You need new ones. Had the same problem and fitted Bosch 808s. Problem solved. There are some threads on the subject with others fitting different blades. John
Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55 ![]() ![]() ![]() |
cool, found some and they are in the basket, but need numberplate bulbs, started a different thread to seporate the subjects
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1754 ![]() ![]() ![]() |
the real reason for the thud is actually because they need adjusting.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35675 ![]() ![]() |
this is what Ash is referring to,
