![]() | Home > Technical (L322) > Folding side mirror judder |
| Webbie Member Since: 02 Apr 2016 Location: Corby Posts: 137
This is my first ever post, I' had my 2011 4.4 TDV8 Autobiography for about four months and am very pleased. The car has no major falls at all after, I've done just over 7000 miles in it so far, with 60,000 miles now in total on the clock. But I do have a few tiny little niggles, the first of which follows:
| bwelton Member Since: 26 May 2014 Location: Milton Keynes Posts: 140
Unnecessary quote removed
| nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690
I had same problem and used "CorrosionX" (It was from Haylands that I learned about this product, thanks Haylands |
| CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1431
Mine has this too. I was told by a dealer technician that the lubricant on the post on which the mirror swivels gets pushed off the section used between the driving and folded positions and the thing to do is to push the mirror forwards from the driving position to draw some lubricant back on to the stem. You might want to verify that elsewhere before trying it though. Only Range Rovers since 1988 |
Does anyone know if the whole unit needs to be stripped down and lubricated, or if there a point where the mirror can be squirted with a lubricant such as Corrosion-X?
No striping, I manually folded mirror squirted some CorrosionX.Give couple days for it to work. |
Thanks for the advice, will give it a go. |
| All times are GMT |
