![]() | Home > Technical (L322) > TdV8 miss ? Update |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1847 ![]() ![]() |
Seen quite a few dodgy oil temperature sensors causing misfires (due to incorrect readings)
DaveK Member Since: 18 Oct 2013 Location: StHelens Posts: 792 ![]() ![]() ![]() |
You condemned it but who had to replace it ? |
Ivor Member Since: 26 Jun 2015 Location: Aberdeen Posts: 223 ![]() ![]() ![]() |
have you changed fuel recently mine does this when it's cold outside and i have tesco fuel in changed it to shell and no more issues L322 2008 vogue
I'll be replacing both of them. 120k miles, no previous history of them being done, and one valve definitely faulty ![]() Along with the front to rear brake pipes ![]() |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Were any of them current? Return once cleared? |
Cleared yesterday, won't have access to read them again till later today so I'll be able to check then. |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
I know diesel is no where near as nice as the good old V8 however didn't realise the diesel were measured in Cat power and not horse power ! |
Been running on Shell and the problem hasn't manifested it's self. Had a couple of weeks of using Morrisons/ Asda fuel and it came back ! |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 ![]() ![]() ![]() |
Take a look at the injector balance using some kind of diagnostics tool. Value should be between 0.8 and 1.3 but ideally close to 1.0. If one injector is deviating much from the others that may need to be replaced or maybe a tank or two with injector cleaner would do the trick... "Plentraktoren/Garden tractor": 2008 L322 TDV8
TheBigChevyGuy Member Since: 30 May 2016 Location: Essex Posts: 9 ![]() ![]() ![]() |
My car was doing this misfire thing when first starting, not all the time mind. Once it did it very bad and also chucked out a belch of smoke. Always cleared and drove fine NO CHECK ENGINE LIGHT! However i checked it with sdd and found - circuit low egr valve - and - minimum stop performance - sorry can't remember the codes... Both faults were intermittent and pending. Put a pair of EGR valves on, not done any misfiring since! Job jobbed! |
