Home > Technical (L322) > TdV8 miss ? Update
DaveK
United Kingdom 2013 Range Rover Vogue TDV6 Corris Grey
TdV8 miss ? Update
Some times when starting from either hot or cold, it feels as if the TdV8 3.6 has a slight misfire, the sort you'd get if you had a dodgy spark plug on a petrol. I select drive and start to move off, it goes after a hundred yards or so. Totally intermittent . 76, thousand on the clock.
Will check and see if any fault codes are stored later this week but no EML's on or any other warning signs. Thought I'd better check the CAT but he seemed quite happy !!
Post #406830 28th Sep 2016 6:24pm
Mikey
Seen quite a few dodgy oil temperature sensors causing misfires (due to incorrect readings)
Also condemned an EGR just last week, causing a misfire for approx 60 secs when starting from warm
Both can be confirmed by watching the live data Thumbs Up
Post #406865 28th Sep 2016 9:34pm
DaveK
You condemned it but who had to replace it ? Whistle Its one of those things that if it is an EGR and you strip down, you've really got to do both cos Sods law dictates the other one will go with in weeks. Cant get it on any machines till Friday afternoon
Post #406873 28th Sep 2016 10:24pm
Ivor
United Kingdom 2008 Range Rover Vogue TDV8 Java Black
have you changed fuel recently mine does this when it's cold outside and i have tesco fuel in changed it to shell and no more issues L322 2008 vogue
R53 Cooper S Works tuned beyond the works SOLD
R33 Nissan Skyline in rebuild 400bhp atw
Post #406895 29th Sep 2016 12:20am
Mikey
I'll be replacing both of them. 120k miles, no previous history of them being done, and one valve definitely faulty Thumbs Up
Along with the front to rear brake pipes Big Cry
Post #406909 29th Sep 2016 7:35am
DaveK
Haven't had a EML come on but these codes popped up this afternoon when I had a quick 10 minutes on a mates Solus.
Post #407042 29th Sep 2016 9:53pm
Were any of them current? Return once cleared?
Post #407064 30th Sep 2016 1:38am
DaveK
Cleared yesterday, won't have access to read them again till later today so I'll be able to check then.
Post #407079 30th Sep 2016 7:27am
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
I know diesel is no where near as nice as the good old V8 however didn't realise the diesel were measured in Cat power and not horse power ! Very Happy
Post #407200 30th Sep 2016 11:02pm
DaveK
Been running on Shell and the problem hasn't manifested it's self. Had a couple of weeks of using Morrisons/ Asda fuel and it came back !
Post #412499 7th Nov 2016 10:45am
SveinHa
Norway 2008 Range Rover Vogue TDV8 Buckingham Blue
Take a look at the injector balance using some kind of diagnostics tool. Value should be between 0.8 and 1.3 but ideally close to 1.0. If one injector is deviating much from the others that may need to be replaced or maybe a tank or two with injector cleaner would do the trick... "Plentraktoren/Garden tractor": 2008 L322 TDV8
"Project": 1990 90 County 300tdi
Post #412516 7th Nov 2016 12:09pm
TheBigChevyGuy
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
My car was doing this misfire thing when first starting, not all the time mind. Once it did it very bad and also chucked out a belch of smoke. Always cleared and drove fine NO CHECK ENGINE LIGHT! However i checked it with sdd and found - circuit low egr valve - and - minimum stop performance - sorry can't remember the codes... Both faults were intermittent and pending. Put a pair of EGR valves on, not done any misfiring since! Job jobbed!
Post #413007 10th Nov 2016 9:38pm
