![]() | Home > Technical (L322) > Front Arm Ball Joint Removal, job done with pics |
RRBlue Member Since: 24 Feb 2012 Location: Cambs Posts: 226 ![]() ![]() ![]() |
Spray, hammering, spray, chiselling, spray, impact chiselling, heat, spray, more hammering, spraying and chiselling. It is all about breaking a ring of corrosion between the ball joint body and the hub. Nightmare. Main problem is lack of clearance for swinging various hammers. 2014 5.0 L405 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
If it's the one in the hub with the two ears and knocks out downwards then I heated mine up with a gas touch and hammered it from the top and inwards and also drove a chisel in under the ears where the bolts go through and it started to move. I did consider chopping of the ears and putting a socket or spacer over the threaded section and drawing it out using a nut on the thread but this may just pull the ball out of the joint..
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Heat
If it's the one I'm thinking of that type of splitter won't do it, the other thing I did was get the jack supporting the hub next to it to give me something to hammer against.
I had to do a small mod on my splitter to open the throat a few MMs.
cliffy Member Since: 17 Apr 2010 Location: Surrey Posts: 556 ![]() ![]() |
Done it just got to get tracking done
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
Bit late to the party but next time try a proper penetrating oil. WD40 is pretty good but there are better, fundamentally WD40 was not designed as a penetration agent. Says something when the company behind WD40 make their own penetrating spray that isn't WD40.
For the sake of a very small amount of never seize on the FF assembly line all this can be avoided, it could save millions of wasted man hours.
WD 40 make a specialist fast release spray and Halfords do a shock and unlock spray which I have used both on large bolts on the RR.
Went caveman on them
Nice one, did you remember to tighten the inner arm pivot points with the weight on the car?
Rapiscan Member Since: 28 Apr 2018 Location: North Lincolnshire Posts: 182 ![]() ![]() ![]() |
Is it not possible to drill out as much material as poss from the flat upward facing disc of the ball joint so creating room to smash the outer metal inwards away from the circular aperture of the hub carrier and lessen its grip? I'm about to tackle mine and it sounds a nightmare!! |
GDM Member Since: 21 Nov 2016 Location: West Sussex Posts: 165 ![]() ![]() ![]() |
Probably not, there isn't a lot of room with the hub still on the car. |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850 ![]() ![]() |
Holiday Chicken
