Home > Technical (L322) > Front Arm Ball Joint Removal, job done with pics
cliffy
2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Im doing battle with the lower control arms on my l322 2004
done the front one no issues, but i cannot get the pressed ball joint out on the upper one
I've gone caveman on it with no joy, has anyone used a puller or can anyone suggest a creative way to remove it?
I am now thinking angle grind a bit of the edge off hopping to be able to knock it threw after
thanks
Neil
Post #407393 2nd Oct 2016 6:16pm
RRBlue
England 2005 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
Spray, hammering, spray, chiselling, spray, impact chiselling, heat, spray, more hammering, spraying and chiselling. It is all about breaking a ring of corrosion between the ball joint body and the hub. Nightmare. Main problem is lack of clearance for swinging various hammers. 2014 5.0 Supercharged Autobiography & 2015 3.0SDV6 HSE Lux Discovery 4
2005 4.2 Supercharged Vogue SE & 2011 3.0SDV6 HSE Discovery 4
2002 4.4 Vogue
2000 4.6 Vogue
2010 Freelander 2 TD4 HSE
2009 Freelander 2 TD4.e 2009
1992 Mercedes 300D
1986 Renault 2.1 Turbo D
1976 Morris Marina 1.8
Post #407412 2nd Oct 2016 7:09pm
holidaychicken
If it's the one in the hub with the two ears and knocks out downwards then I heated mine up with a gas touch and hammered it from the top and inwards and also drove a chisel in under the ears where the bolts go through and it started to move. I did consider chopping of the ears and putting a socket or spacer over the threaded section and drawing it out using a nut on the thread but this may just pull the ball out of the joint..
Heat and hammer and chisel , I have a small club hammer which is a nice size and heavy.
Post #407467 2nd Oct 2016 11:22pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Heat
Soak with WD40 over night.
Heat
Get something like this on it;
http://www.ebay.com.au/itm/like/121961407217?lpid=107&chn=ps
Throw the dunny door at it mate
Post #407473 3rd Oct 2016 12:00am
holidaychicken
If it's the one I'm thinking of that type of splitter won't do it, the other thing I did was get the jack supporting the hub next to it to give me something to hammer against.
Have a look here if I am allowed to post to the a different forum, its after the cv joint removal
https://www.landyzone.co.uk/land-rover/cv-...st-3432851
Post #407478 3rd Oct 2016 4:11am
RR P38
I had to do a small mod on my splitter to open the throat a few MMs.
Patience helps.
I know it can be very frustrating getting ball joints out.
When ever I re assemble I always put a touch of never seize on this sort of component, mind you I have never had to change the sods on any of my vehicles over the last 30 years, but im sure the next spanner monkey appreciates it.
Thats a good pictorial, I cant believe how rotten the underside of FFs get in the UK, I wouldnt buy any of the vehicles that I see the underside of in the UK.........must be the salt on the roads in winter I guess.
We get waves of collectors through aussie looking for cars from the outback (its dry) old landrovers are popular currently, picking them up cheap and shipping them back to the UK is profitable it seems, Japan is a pretty popular destination as well.
Post #407483 3rd Oct 2016 7:23am
cliffy
Done it just got to get tracking done
Cheers guys
Post #407566 3rd Oct 2016 7:12pm
sako243
Bit late to the party but next time try a proper penetrating oil. WD40 is pretty good but there are better, fundamentally WD40 was not designed as a penetration agent. Says something when the company behind WD40 make their own penetrating spray that isn't WD40.
I had my eyes opened a while ago and bought some Swarfega Duck Oil. Makes a hell of a difference compared to WD40, another recommended one is PlusGas. Well worth having a small spray bottle of it lying around.
That combined with my latest toy, an impact hammer rated to 1500+ftlbs when undoing (it's "low" torque setting is 100ftlbs FFS) most things shift pretty easily. Thumbs Up Ed
Post #407585 3rd Oct 2016 8:12pm
RR P38
For the sake of a very small amount of never seize on the FF assembly line all this can be avoided, it could save millions of wasted man hours.
50/50 trans fluid and kero is a great penetrant.
Post #407610 3rd Oct 2016 10:05pm
holidaychicken
WD 40 make a specialist fast release spray and Halfords do a shock and unlock spray which I have used both on large bolts on the RR.
Did you use dynamite to get those out ??
Post #407641 4th Oct 2016 6:35am
cliffy
Went caveman on them
But I can feel it today, on a plus car is all back together lol and the bushes were all mullered all round, anti roll bar bush is now on my list as well
Post #407643 4th Oct 2016 7:40am
holidaychicken
Nice one, did you remember to tighten the inner arm pivot points with the weight on the car?
I drove mine up on two railway sleepers so I could get underneath with my torque wrench, happy days!!
Post #407645 4th Oct 2016 8:16am
Rapiscan
England 2007 Range Rover Vogue TDV8 Santorini Black
Is it not possible to drill out as much material as poss from the flat upward facing disc of the ball joint so creating room to smash the outer metal inwards away from the circular aperture of the hub carrier and lessen its grip? I'm about to tackle mine and it sounds a nightmare!! Shocked 2008 L322 Vogue 3.6 TDV8 in Java Black with parchment and Navy interior. 125000mls.
I used to be indecisive and have a split personality... but we are ok now...I think?
Post #524873 14th Aug 2019 11:34pm
GDM
United Kingdom 2006 Range Rover Vogue Td6 Zambezi Silver
Probably not, there isn't a lot of room with the hub still on the car.
Post #524989 15th Aug 2019 8:26pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Holiday Chicken
How did you stop your railway sleepers sliding forwards when driving up onto them?
Post #525209 18th Aug 2019 10:21am
