Home > Technical (L322) > EGR valve replacement L322 TDV8 3.6 |
SveinHa Member Since: 22 May 2016 Location: Karmøy Posts: 36 |
Anyone have experience with the Auto Code Store EGR emulator? "Plentraktoren/Garden tractor": 2008 L322 TDV8
3rd Oct 2016 4:17pm |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 |
I fitted emulators in June. The motor seems a little quieter and smoother. I assume because it's breathing clean air all the time.
3rd Oct 2016 10:51pm |
stefan063 Member Since: 28 Aug 2016 Location: Kragujevac Posts: 39 |
Best post/user guide ever... |
19th Nov 2016 6:54pm |
Realist Member Since: 13 Feb 2016 Location: Wales Posts: 436 |
Wish I had the guts to do my own work but just had two new EGR valves fitted and cost me £1103.00.
19th Nov 2016 9:04pm |
nick0303 Member Since: 10 May 2017 Location: Halesowen Posts: 16 |
I am planning on following this excellent how to write-up and replace the EGR valves over the forthcoming bank holiday weekend.
10th May 2017 5:06pm |
Edfors Member Since: 26 Oct 2012 Location: Uppsala Posts: 168 |
Thanks, I removed one set of LR004250 from the first post now. Supporter and maintainer of EDF - Mrs Edfors' shopping cart. |
15th May 2017 6:51pm |
Thanks for getting back to me. I wasn't nitpicking by the way. I think your post is excellent. It is just that I wanted to make sure I had all the required gaskets before getting stuck in on a 3-day bank holiday weekend.
15th May 2017 10:54pm |
BigJon Member Since: 05 Apr 2013 Location: Adelaide - Lower Mitcham Posts: 14 |
Great write up, very useful and lots of great pictures. I used it as a reference when changing my thermostat on the weekend.
12th Jun 2017 11:18pm |
Bigbangman Member Since: 10 Jun 2010 Location: Worcestershire Posts: 51 |
Hi,
13th Jun 2017 12:36pm |
Take top turbo hoses off to inspect. A visual while fitted can be ineffective. Check easy things first. ______________________________
13th Jun 2017 9:08pm |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
That sort of time scale could indicate turbo actuator problem. |
13th Jun 2017 9:34pm |
Gavin Member Since: 28 May 2018 Location: Bicester, Oxfordshire Posts: 1 |
Can't thank you enough for the post, all the photos etc were an awesome help. Just finished changing the left hand egr, engine light has gone off and the car runs perfectly again! |
28th May 2018 2:49pm |
322lmk Member Since: 14 Feb 2014 Location: Limerick Posts: 4 |
I recently did both EGR's on my L322 TDV8. The original LR factory ones were marked Valeo. The protective side plates in the write up do not need to come off. Remove both front right angle elbow air hoses off the plastic manifold before manipulating the manifold back and out from under the wiring harness. It will come out. I also removed the EGR valve outlet pipes from the manifold afterwards, cleaned them out and refitted with new o-rings. Also scraped off carbon build up inside the manifold near the 6 inlet/outlets. Before fitting the new valves, I also replaced the two 90 degree coolant elbow hoses forward of the valves. The egr coolers can be cleaned through with a .22 rifle brush. 2007 3.6 L322 Vogue (SE)
21st Feb 2019 12:02pm |
rwilson Member Since: 17 Jan 2011 Location: London Posts: 84 |
Thanks for the guide. Changed the pair of them this morning, took about 3 1/2 hours to do and relatively straightforward. No fault code reader required , just basic tools, it’s just plug 'n play. I fitted valeo parts which were £418 for the pair and didn’t require additional parts.
4th May 2019 3:30pm |
