|  | Home > Technical (L322) > 4.4v8 transfer fluid |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | Castrol BOT 26 FMB 1, as far as I have seen there is no other alternative.
|  4th Oct 2016 12:10pm |
| Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76      | Transfer box - TRANSFER BOX, TL7300 - SHELL TF0753 - IYK500010
|  6th Oct 2016 7:30am |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419    |
 Wrong model for the OP, assuming it's for a 2003 4.4 V8 as per his profile, RR P38 is correct. The fluids differ as later models have a 'locking' centre diff where as earlier ones have a Torsen centre diff. | ||
|  6th Oct 2016 8:14am |
| RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215      | OP, do you have a diesel? | ||
|  6th Oct 2016 8:50am |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1044    | As Weejock says, the OP stated that he has a 2003 4.4 V8 which is fitted with the NV 225 transfer box which, as RR P38 correctly stated, uses the Castrol BOT 26 FMB 1 75W-90 fluid. The change to the Magna Steyr DD295 transfer box happened at the same time as the change to the ZF 6HP26 transmission i.e. 2006 MY for petrol models and 2007 MY for diesel models.
|  6th Oct 2016 9:17am |
| Mcfly309 Member Since: 24 Mar 2016 Location: North Lincolnshire-ish Posts: 76      | Sorry, my bad.   | ||
|  6th Oct 2016 2:29pm |
| mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101      | thanks for the helps lads, bought some,Got to fit a new front diff. So I am going to change this and the rear diff oil to. | ||
|  8th Oct 2016 8:01am |
| mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101      | Mine ended up taking 1.2 litres till it started dripping out the fill hole | ||
|  12th Oct 2016 6:11pm |
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964      | They are filed with a measured amount , filling to the fill hole is overfilled so you should drain and re-fill ( what a lot of fill's)but you see what I mean but its all in the Wiki under Recommended Lubricants . 2008 MY Supercharged
|  13th Oct 2016 3:36am |
| Posting Rules
