Home > Technical (L322) > 4.4v8 transfer fluid
mattyp
I am going to change the transfer box fluid on my 2003 4.4 v8. What is the best one to put in it ?
Post #407675 4th Oct 2016 12:29pm
RR P38
Australia 2003 Range Rover Vogue 4.4 V8 Java Black
Castrol BOT 26 FMB 1, as far as I have seen there is no other alternative.
Its expensive, but you only need 1 litre.
If your oil looks like crap when it comes out put some 75/90 synthetic through (same as the Difs, drive the block drop it out and refil with the Castrol.
Post #407680 4th Oct 2016 1:10pm
Mcfly309
Transfer box - TRANSFER BOX, TL7300 - SHELL TF0753 - IYK500010
1.25 litres required on a 2012 TDV8 4.4
Get in touch with Dan @ Duckworths, it's cheap enough.
Hope this helps Thumbs Up
Post #407886 6th Oct 2016 8:30am
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
Hope this helps
Wrong model for the OP, assuming it's for a 2003 4.4 V8 as per his profile, RR P38 is correct.
The fluids differ as later models have a 'locking' centre diff where as earlier ones have a Torsen centre diff.
Post #407896 6th Oct 2016 9:14am
RR P38
OP, do you have a diesel?
Post #407903 6th Oct 2016 9:50am
RRPhil
As Weejock says, the OP stated that he has a 2003 4.4 V8 which is fitted with the NV 225 transfer box which, as RR P38 correctly stated, uses the Castrol BOT 26 FMB 1 75W-90 fluid. The change to the Magna Steyr DD295 transfer box happened at the same time as the change to the ZF 6HP26 transmission i.e. 2006 MY for petrol models and 2007 MY for diesel models.
Phil
http://www.fullfatrr.com/gallery/albums/us...ssions.jpg
Post #407904 6th Oct 2016 10:17am
Mcfly309
Sorry, my bad. Embarassed
The bit about contacting Dan is correct though.
Post #407945 6th Oct 2016 3:29pm
mattyp
thanks for the helps lads, bought some,Got to fit a new front diff. So I am going to change this and the rear diff oil to.
Post #408249 8th Oct 2016 9:01am
mattyp
Mine ended up taking 1.2 litres till it started dripping out the fill hole
Post #409050 12th Oct 2016 7:11pm
They are filed with a measured amount , filling to the fill hole is overfilled so you should drain and re-fill ( what a lot of fill's)but you see what I mean but its all in the Wiki under Recommended Lubricants . 2008 MY Supercharged
Post #409095 13th Oct 2016 4:36am
