![]() | Home > Maintenance & Mods (L322) > 1l engine oil refill every 1.000 km ? |
| Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3284
Definitely not normal usage! I barely put any in mine between services. I would say you have a leak, poss a cam gasket or poss out of the drive shaft junction underneath where it goes into the gearbox or the engine. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8825
153,000 miles (246,000km) and it doesn't use a drop, ever....
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Check out the small rubber hose coming from the oil separator at the rear of the engine, it's on the left side as you look at it from the front.
"flipper"!! |
| Rambles Member Since: 16 Apr 2011 Location: UK Posts: 850
+1 |
| All times are GMT |
