Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive
Page 2 of 6 <123456>
miggit
Yes and No Shocked
Yes it's locked to one vin number, BUT you can buy extra licences and add other cars to it, I think that 4 is the max before you have to get the pro, which is open to all Bow down
But lets face it they'll have locked you up and thrown the key away before owing 4 ffrr's Rolling with laughter Rolling with laughter Yesterday I couldn't spell Engineer... Today I are one!
Post #408071 7th Oct 2016 9:40am
Buff Rio
United Kingdom 2009 Range Rover Westminster TDV8 Mariana Black
Laughing Laughing 2006 3.0 TD6 Vogue Black - sold
2011 4.4 TDV8 Vogue SE Black - sold
2007 4.2 supercharged Vogue SE Grey - sold
2003 4.4 V8 Vogue green - sold
2009 3.6 TDV8 westminster mariana black 59 plate - current
Post #408080 7th Oct 2016 10:37am
Vanhoolt8
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Cairns Blue
Hi i have a 4,4 autobiography and i have the HDC fault and air susoension inactive and all the lights on and stuck in normal ride height i have put on my code reader and it says CAN bus fault and will not clear any body any ideas
Post #408498 9th Oct 2016 6:15pm
^^^ Which code reader?
Needs the spec of an IIDTool, Solus, Hawkeye, Testbook to clear hard faults on the suspension .
Post #408504 9th Oct 2016 6:45pm
miggit
Firstly check battery voltage, needs to be 12 volt + no to cause silly messages on the screen of doom
Then I'd be unplugging the sat nav, and amps, radio, TV in the boot to see if that clears the message.. either one at a time or all, and then reconnect 1 at a time Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #408505 9th Oct 2016 6:46pm
Vanhoolt8
Hi another forum says it could be an ABS sensor that triggers these messages
Post #408526 9th Oct 2016 8:35pm
Vanhoolt8
Hi my code reader is a carsoft i930 it is for all Land Rover and jaguar models and it comes up with CANbus fault and will not clear the first time i tried it the fault cleared and then when i set off out of the driveway the messages came back on and the ABS light
Post #408528 9th Oct 2016 8:41pm
The canbus fault is a standard fault that most early BMW FF's have, when Ford bought RR they wouldn't pay BMW to remove some faults that were standard to the systems, hence a fare few faults appear on all FF's
If it is an ABS sensor then it is the rear N/S one which does the speed sensor, you know if it has failed as the speedo won't work...
You need a better code reader to get to the bottom of yours if the one you have isn't showing any other faults... Thumbs Up Pete
-Click here for Thread-
Post #408534 9th Oct 2016 8:56pm
Vanhoolt8
Thanks Pete my speedo is still working so which code reader do you suggest to get to the bottom of it cheers Nigel
Post #408538 9th Oct 2016 9:07pm
Personally I wouldn't have anything other than an IID tool but at over £400 they are not cheap....
Thumbs Up Pete
Post #408543 9th Oct 2016 9:14pm
Vanhoolt8
Hi Pete thanks for that i have just found one on ebay for £275 this must be a good buy then for probelems on L322 then do they go into more detail
Post #408550 9th Oct 2016 9:31pm
Is it a blue tooth one? and they are type specific, ie 2002-2005 etc they can read and do more than the system the dealers use...
Just make sure it's the correct one, if that's a new one it's probably not blue tooth which means it won't do as much and uses the dash to tell you faults etc so if your pixels are going you will have trouble... Thumbs Up
Best to read the IID tool site
https://www.gap-diagnostic.com/products/iidtool/ Pete
Post #408563 9th Oct 2016 10:50pm
Buff Rio
Update.
Ok got the diagnostic tool. I'm afraid I wimped out and got the icarsoft i930. Plugged it in and read faults and cleared them and seems to be all working fine. I not so cleverly didn't take a note of the codes so now don't know what the problem was unless it stores them in the tool. Anyway no doubt they will be back if it is more than just a blip in computers.
Thanks for everybody's help on this
Cheers Chris 2006 3.0 TD6 Vogue Black - sold
Post #408767 11th Oct 2016 11:34am
Glad your sorted... Thumbs Up I do that as routine... clear the faults and see if they return, otherwise you just waste money on bit's you don't need.... Pete
Post #408793 11th Oct 2016 3:02pm
Vanhoolt8
Hi I have put my code reader on agin today and I am getting precharge pump fault so I have put another one on still got same faults and will not clear I also have precharge pump pressure sensor fault and don't know where to find that but I also checked wires to pump and no live any body any ideas
Post #408836 11th Oct 2016 7:47pm
