![]() | Home > Technical (L322) > 6HP26X multi plug leak |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1863 ![]() ![]() |
Remove sump, pull down locking tab which releases the sleeve |
sako243 Member Since: 26 Dec 2013 Location: Wales Posts: 613 ![]() ![]() ![]() |
That's what I suspected. Thanks for confirming Mikey. Oh well give it another oil change whilst I'm at it then, better check how much I have left over from the one a short while ago... Ed |
Hammer Member Since: 14 Oct 2012 Location: Perth Posts: 124 ![]() ![]() ![]() |
I have the same symptoms. Is there a post/details for the repair somewhere?
Phil's mentioned it over here
Thanks Ed 2015 AB 5.0 Supercharged
No worries, the ZF procedure is over on disco3.com (hopefully that link works from my mobile).
Well job done, only difficulty was that the sleeve is in a difficult location. Old one came out no trouble at all one the latch was released. Pushing the new one in was a little tricky. You must line up the notch on the sleeve which is about 5 o clock on the gearbox.
