![]() | Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
As far as I'm aware, yes.
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 481 ![]() ![]() ![]() |
I have the i930 too, have you tried reading the reservoir pressure? It's tricky to work out, you go to read values or something along those lines, then scroll to reservoir pressure, press enter, then press esc and it will show you the live value.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Using the i930 do a data stream in the eas part of the menu...select reservoir pressure and it will tell you what the pressure is..mine wouldn't go any higher than 0.09 bar...narrowed it down to either the resovoir pressure sensor or the compressor...turned out it was simply the compressor that was knackered... |
Buff Rio Member Since: 29 Dec 2012 Location: Banstead Posts: 36 ![]() ![]() ![]() |
ok, I did the pressure reading on the data stream and it says 9.14 bar. so think that's ok isn't it ? 2006 3.0 TD6 Vogue Black - sold
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
No, thats about 132psi it wants to be around 180psi which is 12.5bar... |
Not sure how acurate the i930 is now! Mine is showing 11.57 sitting at road driving height..can it vary Pete or do I have an issue...irregardless I'm defo getting the iid tool as I have a couple of faults it cant read... |
That's 167, still a bit low... mine is always smack on 180 when the compressor has finished filling... are you waiting for it to fill completely? it will turn the compressor off if it gets too hot and then top the system up a few minutes later when it's cooled down... |
Hi Pete
Come to think of it I have been taking readings once the light on the dial stops flashing..will double check... |
This has worried me now, mine sits at 11.2bar (also measure on iCarsoft i930)... Will have to test again once front shocks have been replaced!! |
Tested mine tonight! Once it reaches off road or standard driving height it sticks at 11.57? Compressors a month old and cars not throwing faults..simply refuses to go to said pressure...funny feeling it's the icarsoft giving me an incorrect reading..well I hope it is |
From RAVE...
Me too! Hopefully the new compressors not dodgy |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
Sorry for the late reply, I charge for my service's but I'm not expensive £30 for the first half hour plugged in full diagnostics on car and LPG if I can't read it for any reason there is no fee (just a call out charge should I be working mobile) I travel to leeds, stoke on trent regularly, I can give some advice online for free (I won't give advise that could be dangerous to someone not really knowing what they are doing) hope this is of help to you |
