Home > Technical (L322) > Help: ZF 5HP24 Transmission vibration l322 V8 2002
ohuntsman
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zambezi Silver
When cruising on the motorway an intermittent noise in the cab comes from under the gear shifter that sounds like driving on the white rumple line on the motorway.
Is anyone familiar with the noise? Problem? Solution? Question Sad
Post #410998 27th Oct 2016 9:18pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Like driving over a cattle grid maybe? ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #411000 27th Oct 2016 9:24pm
ohuntsman
Not that intense, you know that white line at the edge of the central reservation on the motorway or dual carriageway when you dose off slightly and it wakes you up when you drift over it- a softer version of that
Post #411021 27th Oct 2016 10:15pm
holidaychicken
Is it worse when accelerating slowly up a slight incline , does it stop at around 60 mph and does the Rev counter move slightly when it vibrates ?
Post #411038 27th Oct 2016 11:56pm
ohuntsman
Yes to the slight incline, not sure on the other bits but it will happen at slower speeds- I would tak it for a test drive but it failed it's mot yesterday so totting up jobs for the weekend.
Have you had a similar experience?
Post #411108 28th Oct 2016 12:28pm
holidaychicken
typical torque converter failure is vibration up until around 55 to 60 mph when holding a steady light accelerating throttle up a slight incline.
you will need RRPhil if it is
it is very common around the 100k + miles
Post #411186 28th Oct 2016 9:58pm
ohuntsman
Thank you buddy, I've pm'd RRPHIL Thumbs Up
When it fails what does it need doing to it?
Post #411195 28th Oct 2016 10:31pm
holidaychicken
Normally if it is just the noise and nothing else then phil keeps the refurbished items on the shelf and it's a case of transmission off, swap over TC, transmission on which sounds simple and it is if the transmission didn't weigh so much.
When i did mine I also rebuilt the transmission and phil also keeps those on the shelf but if there is no other symptoms then it's just a case of swapping the TC.
Post #411202 28th Oct 2016 11:33pm
ohuntsman
How long did it take? Do you need the jig tool?
Post #411203 28th Oct 2016 11:46pm
You don't need any special tools, tranny out and in is a good days job with a ramp, on the floor I'd allow a weekend for it... Book time is 5 hours...
You will not lift it on your own unless you are Mr universe so you need to phone a friend... or two... Thumbs Up Pete
Post #411215 29th Oct 2016 12:58am
holidaychicken
And get a transmission jack, and we made full length ramps but as a decent garage can do it in a few hours then i would ask an indy but get your TC from Phil so you know it has been properly refurbished as it is a specialist job.
Couple of fots below of it leaving the mothership and the ramps we made and yes we did brace between the supports to stop them folding up on us.
The transmission complete looks like it should be orbiting the earth not being maternally extracted from under a RR.
And the refurbished TC waiting to go back in
Post #411322 29th Oct 2016 8:13pm
ohuntsman
Ahh awesome thank you buddy- how much did the repair cost you?
Post #411324 29th Oct 2016 8:20pm
Much easier if you take the transfer box off the back first, doesn't spill any oil or need any gaskets, does make it that bit easier though.... Thumbs Up Pete
Post #411328 29th Oct 2016 8:54pm
holidaychicken
I have since removed and refitted the transfer box separately and that does weigh a lot on it's own and again took me a day to try and get it back in on my own without a lift just a trolley jack and ended up getting a neighbour to help, damn that gravity...
regarding transmission cost, i did a complete strip down after reading everything i could find that RRPhil had ever posted, measured all the clutch packs, replaced the suspect seals that can go as i also had an oil leak at the rear of the transmission and a few bearings, oil, filter etc etc and etc.
i think the service kit and other spares and the TC rebuild was around £600, oil is another £120 i think and must be the mobil LT71141 and the ramps and other stuff and i paid my mate around £500 as he is a top bloke and wasn't working and i would not of attempted it without him and RRPhil was a massive help and without his direct and indirect input i would not have even started the job.
if it is just the vibration and the transmission is fine without any leaks then you could just swap the TC as you don't need to touch the transmission internals
you need to clarify that your noise is the TC as you dont want to be taking the box out without good reason Very Happy
Post #411339 29th Oct 2016 10:33pm
ohuntsman
Coolio thank you- love the ramps- I've been eyeing up two post lifts on gumtree- some 3 tonne ones start at around £400.... but the directors may have something to say about that going up outside the flat Rolling with laughter
Ha! Yes sound advice!
I think what I'll do is get the MOT bits sorted out so it passes and take it for a drive & film the noise then post a video on YouTube so I can get a good diagnosis Thumbs Up
Post #411355 30th Oct 2016 12:12am
