Home > Wheels & Tyres > L322 18" or 20"
sam919
L322 18" or 20"
Hi All,
I've been onto page 15 of this topic and found nothing conclusive, all be it taste related, I would like to know people's thoughts of using 18s or 20s on my FF.
The cars used for hacking around country roads and trailing anything from a small plant trailer to a 3000kg car transporter. I'm not too ars*d about bling, in fact I like the country type off-road look with the smaller 18s if that makes sense.
The car was bought in London, dark blue and has 20" stormers that need a refurb and have accelera tyres on which are ok tread wise but not new.
Do I refurb and re-tyre or sell and look for 18" 5 spokes parallel wheels, not sure of the name?
* I read on this forum about earlier cars only having 18" wheels, later 20" wheels and cars had different drive shafts?
Post #411372 30th Oct 2016 9:48am
Rob99
First off, welcome to the forum. Thumbs Up
What age and model do you have as later ones can't have 18" rims as they won't fit over the calipers. 2021 D350 Fifty Edition - Carpathian Grey
2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black
2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black
Post #411374 30th Oct 2016 9:56am
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Wheel nut change from earlier to later cars, not sure when.......
Later cars 3.6 TDV8 and 4.2SC have larger brakes, smallest rim size is 19"
It depends on which car you have, or intend to have, there are plenty of off road tyres available to suit any of the rims Wink Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #411375 30th Oct 2016 9:57am
sam919
Hi, thanks for the input.......missed the important details.
2003, Td6!
Post #411376 30th Oct 2016 10:11am
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I have 18's on mine and think I will probably stick with them as the country roads I mainly drive on are pot holed. I wonder if the lower profile tyres give the suspension ball joints and bushes a harder time ?
Post #411377 30th Oct 2016 10:14am
For your purposes I would recomend 18" with slightly oversized General Grabber AT's , not much is going to stop you then and very hard wearing . 2008 MY Supercharged
Post #411378 30th Oct 2016 10:20am
sam919
Ok, what size would you recommend ? Over the norm
Biffo- sounds similar, just replaced fronts on this one
Post #411380 30th Oct 2016 10:26am
I have never run 18" so not sure but some one who does will be along soon but at a guess say 255/18/55 if that is even a proper size . 2008 MY Supercharged
Post #411381 30th Oct 2016 10:28am
miggit
Whistle I'd stick with standard 18" set up, with 255/60/18's, there is no way you should think about bigger tyres if your going to be using it for heavy towing... it struggles enough with out playing around with the overall gearing.
The 255/60/18 tyres give a good ride quality, and don't require massive over inflation for stable towing...
Tyres... I'm running General Grabber AT's, the 255/60/18 is a 112H XL, 'XL' stands for extra load... Whistle although I haven't discovered how much extra load is worth, sort of get the feeling that it's about the same as std 112H but with added Bull Laughing Yesterday I couldn't spell Engineer... Today I are one!
Post #411385 30th Oct 2016 10:47am
rar110
I have 265/60/18s (with Compomotive rims) as they are a pretty common tyre on several Japanese 4WDs.
I'm pretty happy with that size and can't say I noticed a change in the drive feel from the 255/55/19s. The extra 3/4" in sidewall height helps with very uneven surfaces. ______________________________
Post #411390 30th Oct 2016 11:23am
sam919
It seems to be pointing that way, I have 20" at the moment.
I used hankook Ventus on my t5, RRS alloys, they were a cracking tyre, grip/ wear/ cost.
Browsing on cam skill
http://www.camskill.co.uk/m65b0s481p0/SUV_..._255_60R18
There seems to be a plethora of 255/60's. Ok your highfly things aren't going to be as good as a Pirelli....
Post #411393 30th Oct 2016 11:28am
Dolphinboy
@sam919,
I had 18" on my first rr and this was definitely the best for comfort, ride and cross country. However 20" on my next rr gave me better cornering on tarmac.
Btw I have a set of 5 x 18" wheels going spare with the 5th tyre being unused spare with the red stripe still on. The other tyres will need changing as they are down to 3-4mm but would suit you if you are going to put new rubber in. Pm me if interested. Thumbs Up
Post #411398 30th Oct 2016 12:08pm
miggit
rar110, the difference between 265/60/18 and 255/60/18 is 10 mm in width and 6mm in height... your tyres are 6mm or 1/4" bigger... sod all in the grand scheme of things, and if Jap sizes are easier to get over there, stick with'em Wink
There are a few issues with 20"rims on a TD6... it is alleged that they cause vibration through the steering wheel at idle or something, but I'm only reporting what I have read, I have no experience of this as I have only run 18"'s on my ffrr... And while a lower profile tyre is favourable for towing, as there is less movement in the sidewall, I would opt for the better ride and increase the rear tyre pressures when towing.. although I didn't really notice any real sway, regardless of the pressure the tyres were at, but between 35 and 40 psi felt the best compromise Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #411407 30th Oct 2016 12:41pm
rar110
Miggit
I accept that's what the standardised sizing would indicate. However, side by side with the 255/55/19 showed different. Even in the same brand and same size there was 10-15 mm difference between the 265/60/18 AT & HT versions. ______________________________
Post #411410 30th Oct 2016 12:59pm
sam919
Thanks for all the suggestions and input. I think I'll go with 18" and look for a full set with decent tyres, the 20" I have on now I'll try and move on once done.
I'll try an pm folk that have offered wheel, the thanks again ...... Great forum with sound advice Thumbs Up
Post #411453 30th Oct 2016 7:28pm
