Home > Technical (L322) > front sensors stopped working
Page 1 of 3 123>
BOBCUSSEN
France 2004 Range Rover Vogue Td6 Java Black
HI guys Bow down
my front sensors have stopped working? not just one but all of them, one day all was fine, next minute, nothing, ??
does it sound like could be the main module in the rear could have partly failed? as the rear is working fine ::
bob
Post #411758 1st Nov 2016 9:11pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
best thing would be th throw it on a diagnostic machine see what comes up
Post #411788 1st Nov 2016 10:49pm
CharlieBaja
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
I had this issue on mine. When the ignition is on you have to listen to the PDC's individually as they admit a tapping noise. Each should have the noise and if one doesn't then you know that's the faulty one
Post #411807 2nd Nov 2016 12:15am
BOBCUSSEN
ok so when i put the ignition on, do i have to put it in drive? as its the front ones? or leave it in neutral ?
Post #411822 2nd Nov 2016 9:01am
Lukie
Think you can press the Button on the dash to switch them on then listen for the ticking don't stand in front of a car with engine on a drive engaged!
Post #411836 2nd Nov 2016 10:49am
BOBCUSSEN
i will try that,
thanks guys
Post #411900 2nd Nov 2016 4:32pm
BOBCUSSEN
hi guys
well i have had a listen to each of the four front sensors and as far as i can make out, none of them are ticking, so would you think it points to the control uint in the rear fuse panel could be at fault ? and is there anyway of testing,? IE could i change the rear unit with the front ? as the rears are all working fine??
bob
Post #412076 4th Nov 2016 1:15pm
CharlieBaja
I am guessing you have listen to the rear sensors to know the clicking noise your listening out for? I think they all use the same ECU, so sadly in your case it could be all four individual sensors. Perhaps buy one sensor as a spare and test it out in the front bumper to see if it admits the clicking noise.
Post #412627 8th Nov 2016 9:27am
Usual thing is the wiring loom from the sensors to the car, the rears are always failing and the fronts do to, could be corroded plugs or chaffed wire.. worth checking before changing the control unit, which, if the rears work is unlikely to be faulty... Pete
-Click here for Thread-
Post #412661 8th Nov 2016 4:22pm
BOBCUSSEN
AAH OK. well i would be most suprised if all the front sensors failed at the same time, so would imagine it is perhaps a fault in the main wire running to the sensors ? i will attempt to remove the front bumper and have a look,
i cant listen out for the clicking of the rear ones as they all work and as soon as i try to get near them to listen, they go off !!!, unles im doing something wrong, then please correct me Rolling Eyes
bob
Post #412667 8th Nov 2016 5:24pm
HGv driver
Wales
do the fronts stop working if the rears dont work?
Post #412818 9th Nov 2016 5:59pm
BOBCUSSEN
hi, i dont think i wworded my last reply very well:
the front and rear were all working fine, one day i noticed the fronts just stopped, ( all of them ) , the rears work fine,
i understand to the guys saying to switch the ignition on, then switch the sensors on and listen to the rears so i get to know what the clicking sounds like; but as i said, when i go to listen for the clicking, as soon as i get close enough to a sensor; it goes off, !!! ( not off as in not working ), but goes off as in making the warning sounds !! Embarassed Rolling Eyes Thumbs Up
bob
Post #412826 9th Nov 2016 6:54pm
Stormin
2003 Range Rover HSE Td6 Epsom Green
Don't know if this helps, but on my old TD6 my front never worked from purchase.
However when the suspension pump failed and was replaced, it went in for an software update for the pump, when returned the front were working Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
2010 Range Rover Vogue SE Santorini Black, Arabica Aniline seats
Previous cars
1973 Mini 1000
1971 Hillman Avenger
1975 Chrysler Sunbeam
1981 Ford Cortina
1985 Volvo 340
1989 VW Golf
1989 Volvo 240
1991 Volvo 240
1991 Jaguar Soveriegn
1996 BMW 730
2003 Honda CRV
1999 Jaguar Soveriegn
2003 Range Rover HSE Epson Green with Sand trim.
Post #413254 12th Nov 2016 7:34pm
BOBCUSSEN
hi stormin
well i haven't had a update since i have had the car 2012 Rolling Eyes , but perhaps i will try that, but first i may try and get at the sensors wiring etc, i assume the bumper will have to come off, ? but thanks for the suggestion
bob
Post #413259 12th Nov 2016 7:59pm
BOBCUSSEN
hi guys
to get at the front sensors; i assume the bumper has to come of , bu do i have to also remove the headlights to get the bumper off ??
bob
Post #413290 12th Nov 2016 11:28pm
Page 1 of 3 123>
