![]() | Home > Technical (L322) > front sensors stopped working |
BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296 ![]() ![]() ![]() |
HI guys |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
best thing would be th throw it on a diagnostic machine see what comes up |
ok so when i put the ignition on, do i have to put it in drive? as its the front ones? or leave it in neutral ? |
Think you can press the Button on the dash to switch them on then listen for the ticking don't stand in front of a car with engine on a drive engaged! |
i will try that,
hi guys
CharlieBaja Member Since: 01 Feb 2016 Location: Surrey Posts: 52 ![]() ![]() ![]() |
I am guessing you have listen to the rear sensors to know the clicking noise your listening out for? I think they all use the same ECU, so sadly in your case it could be all four individual sensors. Perhaps buy one sensor as a spare and test it out in the front bumper to see if it admits the clicking noise. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8800 ![]() ![]() ![]() |
Usual thing is the wiring loom from the sensors to the car, the rears are always failing and the fronts do to, could be corroded plugs or chaffed wire.. worth checking before changing the control unit, which, if the rears work is unlikely to be faulty... Pete
AAH OK. well i would be most suprised if all the front sensors failed at the same time, so would imagine it is perhaps a fault in the main wire running to the sensors ? i will attempt to remove the front bumper and have a look,
HGv driver Member Since: 16 Sep 2014 Location: Cardiff Posts: 169 ![]() ![]() |
do the fronts stop working if the rears dont work? |
hi, i dont think i wworded my last reply very well:
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
Don't know if this helps, but on my old TD6 my front never worked from purchase.
hi stormin
hi guys
