![]() | Home > Technical (L322) > Td6 temperature gauge |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^^ well in an ideal world the thermostat would hold the engine at exactly the correct temperature...... But in reality the operation of a thermostat isn't quite so quick.....and this is why the temp goes up and down like a yoyo... hence the statement 75-100 deg should be ok. As you correctly say 88 deg is the correct operating temp.. but I can guarantee that if you monitor what the ECU sees it will only be 88 a fraction of the time. This is why in the good old days Smiths damped their temp gauge to stop the needle dancing up and down, and why LR has opted to rate normal on the ffrr between 70 and 105... it's actually more than that, I think it shows normal from 68, and mine was still showing normal at 105, so that will go higher before the needle moves |
Zulu 10 Member Since: 28 Nov 2014 Location: Hampshire Posts: 88 ![]() ![]() |
Having watched the ECU reported temperature - and with the benefit of the tell-tales in the Torque app - as I did a 650 mile run across France a couple of weeks ago I can report that once warmed up the temperature remained between 89 and 93 for the whole journey. Actually even though I agree about latency in the thermostat, I can't see how all that metal and coolant could go up and down "like a yoyo" across a twenty five degree range.
"I can report that once warmed up "............
Imbigt Member Since: 24 Sep 2016 Location: Romford Posts: 76 ![]() ![]() ![]() |
How did you tap into the top hose to fit the sensor |
Demon Tweeks sell this:
If you have to faff with the egr cooler and stat just remove them. Much simpler and better in the long run for your engine above just possible diesel oil mixing FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Ive ordered an x type jaguar fan pack with the soft start ecu I'm going to fit a new thermostat and remove the egr cooler completely and see what happens. Thanks for all the replys |
Further to my previous quote where I stated that "Normal" is from 68 deg.. I would like to amend that to 72 deg |
