![]() | Home > Technical (L322) > low range |
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
My guess would be the motor that drives the range change on the xfer box.
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Thanks for reply.. Yeah past owner only ever used it for motorway driving and it has never been off road...Ive got plans to get it muddy so I'm definetly needing to sort it out |
pembsRR Member Since: 15 Oct 2012 Location: Wales Posts: 35 ![]() |
I have to say, I put mine in low range just to go up and down our (steep and long) drive every couple of months - it's not needed, but I figure it helps to turn it over every now and then |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
As said above the problems are down to a ring shaped rheostat in the shift motor. There is a thread on here about it but I can't find it at the moment....
I'm going to have to get mine taken off and have it bench tested...will have to make it a priority as I'm heading up north for xmas and the low range will be of great use...also panicking incase it gets stuck in low range ..will do a search for a company that will refurbish my old unit...im sure I've read a post in here about it... |
Cheers for that nmj |
The problem is the potentiometers are the part which fails and these seem to be specific to this unit and No one has successfully found a replacement afaik. There is nothing that can't be fixed with a hammer😜😜
http://www.4x4lro.co.uk/home..anybody tried these guys yet? Cheaper than buying a new unit.. |
Links knackered .. |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
I use mine from time to time also just to keep it from getting sticky.
Cheers..its the same lot I've linked..definite priority now...has anybody replaced their own? Looks easy enough ! Getting the thing back on looks a bit tricky though! I'm loving working on my ff just now but this is out my comfort zone a wee bit |
i think it is in rave and also on youtube, you have to careful about how you remove as there is a part that can be moved either in or out when the motor is removed which will get the transmission confused and if you push it in you cant get it back out without removing the transfer box....
Download rave manual and its in the repair manual as 'Actuator - Ratio control'
