|  | Home > Technical (L322) > p0000 fault code? |
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479      | No idea at all but I've had the same for a while.... | ||
|  9th Nov 2016 5:24pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | I take it yours wont clear either? I'm going to try a battery reset as I've just been informed it could be a glitch. Failing that I've a new upgraded thermostat to fit and hopefully that sorts it out... | ||
|  9th Nov 2016 6:16pm |
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479      | I was considering the thermostat mod to try to clear the fault. Let me know if yours works   | ||
|  9th Nov 2016 6:31pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | The thermostat mod won't clear the fault...
|  9th Nov 2016 7:32pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | I get ya ! ...any idea what could be triggering the fault then ? Car was fine until today until it started idling at 900rpm...that only stopped after I restarted car then fault appeared..only thing I've done to the car before it appeared was to leave a daft phone charger in the cigar socket for a few hours to see if its led switches off after cars asleep...obviously not related...do you think its worthwhile doing a battery reset? Cheers pete | ||
|  9th Nov 2016 8:00pm |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836      | That's odd, I did the thermostat hack / upgrade and I get this fault now,
|  9th Nov 2016 8:21pm |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8826      | It could be a fault within the thermostat but I doubt it, I really wouldn't worry about it and I doubt it has much to do with the engine revs, mine tends to wander around on these cold days, I recon it's something to do with the different air density as the temp drops but that's just my own theory...
|  9th Nov 2016 8:33pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | Funny you should say that..its been damp and freezing up here today.. Worse day if the year and this fault shows.  Will keep an eye in it anyhoo...thanks gents   | ||
|  9th Nov 2016 8:38pm |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836      | Have you had a look inside the thermostat plug? There's been posts on here about them melting and corroding inside near the contacts causing faults.
|  9th Nov 2016 8:45pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | I'm going to have a peak at the weekend when I'm off...is it easy to access plug or do I have to remove the air plenum ect ? | ||
|  9th Nov 2016 8:59pm |
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836      | Probably best to remove the plastic engine cover and the air intake pipe from the air filter housing, not even a two minute job   | ||
|  9th Nov 2016 9:02pm |
| alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801      | Brilliant! Will check that just to be sure...thanks   | ||
|  9th Nov 2016 9:15pm |
| Posting Rules
