![]() | Home > Technical (L322) > Torque convertor ( supplier question) |
Rewmer Member Since: 14 Jan 2013 Location: Essex Posts: 142 ![]() ![]() |
Ive accepted that I need mine replacing - rev fluctuation, cattle grid effect etc and Ive been looking around a various places. J Pat and Sussex autos seem to be the favorites. But then i came across this ad in ebay
davidsmith1307 Member Since: 05 Mar 2015 Location: Hull Posts: 52 ![]() ![]() |
Worth asking RRPhil on here! |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Can't really see the point in paying another £200 on top of the price I paid for mine from Sussex Auto for extra lifespan given the lifespan of my original was 100k+ miles and even then wasn't worn out (replaced as I took the gearbox off for another issue). It's likely my gearbox will need a rebuild before the replacement torque converter wears out.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1012 ![]() ![]() |
I agree that it would be very interesting to hear from anyone who’s tried one of these converters.
ohuntsman Member Since: 21 Mar 2016 Location: Cornwall Posts: 340 ![]() ![]() ![]() |
It seems Doug also repairs & sells all Tefal Activfry machines, does it make me a bad person that all I can see is a torque converter!!!
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I had one of those... I got 25 miles out of it before it destroyed it's self and my gearbox too |
Oh and another lesson learnt, you can't just fit a new / recon converter... only you start playing with the gearbox it really needs to be stripped and cleaned if nothing else, cos your worn out converter will have dumped a lot of grinding past in to the rest of the box.... it will sit there forever until you do something like change the oil... then it gets softened up and goes on a wrecking spree |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Do you have the TD6 and if so was the valve block checked before fitting the carbon fibre TC, just out of interest ? |
First time the gearbox was power flushed.... second time the whole box was stripped and cleaned, and the valves were replaced with Sonnax upgrades... should have been done first time around |
So when the carbon fibre TC failed, was that the first time before the strip down and new sonnax valves? |
Proper one it is then. Diint think about checking out the other items for sale. Never would have put TCs and fryers in the same service supply area 🙀 No7 - 2003 V8 Vogue |
Sorry kevlar, I think the main killer is the valve body wear and then it seems common to replace / repair everything except the root cause which is the valve body and then in what can be a very short time, failure again caused by the lack of pressure to the LUC.
Not so sure that the ZF suffers in quite the same way, being built by the Germans who care about quality, rather than the French who care about dinner |
